Search and replace instance
Hi everybody,
I have list of instance B1,B2,....Bn and A1,A2,....An.
How can i replace B1 = A1, B2 = A2 ... Bn = An by using "search and replace" query
thanks.
dai
  • You mean the names of the new cells are constructed by replacing the "A" prefix by "B"?
    Here is such a custom query:
    with instances of cells * where cell_name ~ "A(*)" do inst.cell_index = <<"B"+$1>>
    This may need some explanation:
    "instances of cells *" is a bit misleading (owned to the pseudo-natural language of the query): it actually means "instances contained in all cells". So "with instances of cells *" is a loop over all instances of all cells.
    "cell_name" is referring to the "cell_name" attribute of these instances, "~" is the match operator. It accepts a "glob pattern" (think shell) and "A(*)" will match all A-prefixed names. The remaining part is captured by the bracket. It will become available as "$1" in the subsequent expressions.
    <<"B"+$1>> is a cell reference by name (name string expression inside double angle brackets) and resolves into a cell index which can be assigned to the instance's cell_index attribute.
    Hope that's not too confusing :)
  • Thanks Matthias,
    This is exactly what I want.
    Your explanation is very clearly Matthias. :heart: :heart: :heart: :heart: :heart:
    :smile: :smile:
    thanks again.
    daipv
