Hi everyone,
I'd like to create a cycle (Radius 1mm) array with 10nmx10nm square. As shown in the images. I draw two layers, How could delete these squares( layer 2) that are not inside of the cycle (layer 1).
Thank you very much in advance.
Please see my other comment. You cannot. 10x10nm on 1x1mm is too small for this kind of processing. Another approach is required.
Ideally there is an algorithm to approximate a circle by a boxes - e.g. an inner square and boxes attaching to that and filling up the circle.
