Unloading layout properties
edited January 2012 in General
I am wondering if it is possible to unload the layer properties, so the original names of the layers can be seen. I could simply reload the entire GDSII file, but with >9GB files, this takes a lot of time.
I accidentally loaded the wrong properties, so instead of reloading the entire file again, could the properties be reset to the original names?
  • edited 12:59AM
    Hallo,
    basically thats possible by using "Select All", "Delete Layer View" and "Add Other Views" from the layer list's context menu (right mouse button) in that order. This will remove all entries first and create new layer views for all layers present, giving them the default settings.
