Hey everyboday,
I am currently working on a Klayout DRC script and I want to test for the existance/presence of a specific cell in a given layout (gds file).
Is there a specific function for that? and/or is there a way to use a conditional operator, for example if/else?
What I tried to do was selecting the targeted cell and layer using the cell("name") and layer functions. This worked, when the cell was present; DRC reported it in the Macro Database Browser. But what I am obiously trying to achieve is, to have the DRC notify me in the case wheret the specified cell is not present in the layout at hand.
Regards
You can use if/else in the DRC script. It's a Ruby script.
You can ask whether a cell exists this way:
thank you for your response.
I implemented this into my script as follows:
_if source.input(#,#).has_cell?("The_cell_name")
else
puts "The_cell_name is missing"
end_
but I am getting an error when running the DRC:
undefined method 'has_cell?' for #<DRC::DRCLayer:0x00000116e62f0
was my implementation faulty? or did I misunderstand what you wrote above?
Thank you again.
It says "source.layout", not "source.input(...)" :-)
Thank you very much! It seems to work.
But unfortunately I'm facing another problem. I cannot print out a message onto the marker browser. When using the variable.output("message") function I am getting the error (output is not defined) and I cannot find any other method to print out messages in the klayout documentation or in the forum. I also tried: puts "message" and no luck.
Could you help me out with this one?
Regards
You can't print into the marker browser, but you can print to the log window (File/Log Viewer) using
log("your message")
Thank you!
Best regards
