xSection 1.4 creates inifinity every time :mode => :round is invoked
I just upgraded to 1.4. The same input file now generates infinity error every time :mode => :round is invoked.
:octagon and :square are working fine, but do not look as good.
Am I doing something wrong ?
Thanks.
Thomas.
  • Hi Thomas,
    could you provide an example?
    Basically 1.4 tries to reduce the number of points of the rounded features would not benefit from a large point count. I assume your case is a border case somehow.
    I'd also appreciate if you could create a ticket with GitHub (https://github.com/klayoutmatthias/xsection/issues) as the XSection script is a separate project.
    will do. But I deleted 1.4 because it wasn't working, so this will take me a while.
    Thanks.
    Thomas.
  • All fixed and working now.
    Posting the resolution here, because it wasn't really a xsection issue:
    delta() was set to some unrealistic value. Doh !
    Thank you !!!
    Thomas.
  • Hi Thomas,
    thanks for this update.
    So it was too small I guess (or even zero). Right?
