Some question about 'erase' in python
Hi
I am using Python scrfipting in marco develpoment to draw patterns. I need to make a ''customized eraser". So I tried the 'erase' function. But it seems like it can only delete an existing obiect that is inserted.
And when I tried a cuntomized shape like:
erase(pya.Box(x1, y1, x1+length, y1+width1)) it gives that: 'erase' is not defined
when I tried:
cell.shapes(layer).erase(pya.Box(x1, y1, x1+length, y1+width1)) it gives: unexpected object type.
It only works when I tried:
cell.shapes(layer).erase(cell.shapes(layer).insert(pya.Box(x1, y1, x1+length, y1+width1)))
But this does not help, because I need to clear everything which is surrounded by a customized shape.
So how to make a general customized eraser or is there any other function to realize my purpose?
  • It is beacuse my pattern has a background, I need to clear some certain parts in order to fit my structure in it. And it dose not help to just erase the background by hand in Editor mode.
  • Hi,
    I think you misunderstood the meaning of "erase": it will take out a specific object from the object collection, not void the area under the shape.
    What you need is a "boolean NOT" operation. Or you need a selective delete. "NOT" is available within the DRC framework, but it will not preserve the hierarchy not labels of the original layer. A selective delete is a difficult operation if hierarchy is involved and shapes need to be deleted from subcells.
    I can't give advise without knowing more about the application you're planning.
  • edited March 2020
    Hi Matthias
    This is my script. I have made the certain shape for the 'eraser' and the background. What I need to do is something like from image 1 to image 2.
    I think it is really difficult to use the 'boolean' operator for my case. It can be much easier if there is a function to customize the shape of 'erase' in Editor mode.
    script
    def block(layout, cell, layer, width, x0, y0,rad,x_r, y_r, width1, length, x1, y1, r):
        theta_start =0
        theta_end =360
        theta = np.linspace(theta_start, theta_end, 800)
        x = rad*np.cos(2*np.pi*theta/360)+(x_r);
        y = rad*np.sin(2*np.pi*theta/360)+ (y_r-width1/2);
        a1=[]
        for i in range(len(theta)):
             a1.append(pya.Point(x[i], y[i]))
        wg_path1=pya.Path(a1,width1)
        theta_start=0  #angle in degree
        theta_end = 90  #angle in degree
        theta = np.linspace(theta_start, theta_end, 200)
        x2 = r*np.cos(2*np.pi*theta/360)+(x1+length);
        y2 = r*np.sin(2*np.pi*theta/360)+ (y1-r+width1/2);
        a2 = []
            a2.append(pya.Point(x2[i], y2[i]))
        wg_path2 = pya.Path(a2, width1)    #turing waveguide
        theta_start=180
        theta_end = 270
        x = r*np.cos(2*np.pi*theta/360)+(x1+length+2*r);
        y = r*np.sin(2*np.pi*theta/360)+ (y1-r+width1/2);
        a3 = []
            a3.append(pya.Point(x[i], y[i]))
        wg_path3 = pya.Path(a3, width1) #turing waveguide
        wg_path4=pya.Box(x1, y1, x1+length, y1+width1)  #straight waveguide
        eraser=[wg_path1,wg_path2,wg_path3,wg_path4]    #the eraser is a combination of four parts
        for o in range(2):
         for u in range(18):
          for i in range(36):
           hull=pya.Box(x0+(2*i+o)*width, y0+(4*u-2*o)*width,x0+(2*i+1+o)*width, y0+(1+4*u-2*o)*width)
           cell.shapes(layer).insert(pya.Polygon(hull))  # background
    if  __name__ ==  "__main__" :
        layout = pya.Layout()
        top = layout.create_cell("TOP")
        l1 = layout.layer(1, 0)
        y0_1=0
        x0_1=0
        x1_1=1000
        y1_1=1000
        width_1=10000
        width_2=10000
        length_1=800000
        r_1=40000
        rad_1=80000
        x_r1=length_1/2
        y_r1=rad_1+width_1+width_1+1000
        block(layout=layout, cell=top, layer=l1, width=width_1,  x0=x0_1, y0=y0_1,rad=rad_1, x_r=x_r1, y_r=y_r1, width1=width_2, length=length_1, x1=x1_1, y1=y1_1, r=r_1)
        layout.write("D:/cmp_block.gds")
        print("Done.")
    Thank you
  • Hi,
    Please format your code using Markdown formatting - put a line with a triple backtick before and after the code. The above form is not quite readable.
    I think boolean operations are basically the easiest way to implement your request. Your script is already producing a layout with the "erase" layer.
    You can then use a DRC script like this:
    # This will remove the "eraser" from layer 17, datatype 0 (example):
    eraser = layout("D:/cmp_block.gds")
    (input(17,0) - eraser.input(1, 0)).output(17, 0)
    If you care to write your script in Ruby you can basically integrate the eraser generation into the DRC script and skip the intermediate file step.
    I finally find the function 'Region'. Just use pya.Region(A)-pya.Region(B), then it gives what I need. And this is what so called 'boolean'. Because I am a noob of coding, it really took me a while to understand how it goes.
    Anyway, thank you for being so helpful.
    Zhan
  • Hi Zhan,
    very good ... that is actually even better. I did not dare to propose this, but this will allow you to implement the feature in a single piece of code.
    "Regions" are basically what is a "layer" on the canvas. The region object allows manipulating and analysing layers in manifold ways. It's a very mighty concept.
    I just would like to point out this:
    • Regions don't represent labels (text objects). Hence such objects will be lost.
    • Regions only know polygons. Paths will be converted into polygons if you use regions. Same for boxes.
    • Regions are flat. If you have a hierarchy of cells, the Regions will represent the flattened view (as looking from the top cell). Boolean operations will then give you the full layer, but the hierarchical composition is lost.
