Hi, Matthias!
I run Clang-tidy (version 9) modernize-use-bool-literals check over KLayout code:
src/gsiqt/qt5/QtCore/gsiDeclQDataStream.cc:111:14: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/laybasic/layLayoutView.cc:1559:17: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/laybasic/layLayoutView.cc:7316:12: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/laybasic/layLayoutViewConfigPages.cc:360:15: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/laybasic/layLayoutViewConfigPages.cc:364:13: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/laybasic/layLayoutViewConfigPages.cc:368:14: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/laybasic/unit_tests/layBitmapsToImage.cc:99:68: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/lay/lay/layApplication.cc:1222:72: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/tl/unit_tests/tlIntervalMap.cc:51:9: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals] src/tl/unit_tests/tlIntervalSet.cc:40:9: warning: converting integer literal to bool, use bool literal instead [modernize-use-bool-literals]
I can read compiler warnings myself. But this has very low priority for me.
