The problem is basically that these constants are not enums. The Qt API is translated automatically by a (complex) script. It cannot deduce the need for these constants from the class interface. So these constants are skipped.
For now, I can only offer to use 1 for Accepted and 0 for Rejected.
In the Qt API this is an "int", not a bool. And it's not an enum, hence the Qt translation script does not recognize it as an QDialog::DialogCode enum and omits definitions for the latter.
Yes, that's right.
Hi, Matthias!
May be
exec()/exec_()
should return Boolean value? In C++ code result ofQDialog::exec()
would be compared withQDialog::DialogCode
.In the Qt API this is an "int", not a bool. And it's not an enum, hence the Qt translation script does not recognize it as an QDialog::DialogCode enum and omits definitions for the latter.
