Hi all, below you can find a python function for swapping Datatype vs. Layer-number in companion with some diagnostic print messages.
As it happend I got some GDS files were I need to swap the layer. The project partner statement was: "we have done it always that way we can't change" .
The function takes a pya.Layout object as argument and returns a new one.
I am wondering if this could have been done much simpler (of course with pya) ?
def swap(source_layout):
dbu = round(source_layout.dbu, 9)
print("DBU:", dbu)
print("All Cells:", [source_cell.name for source_cell in source_layout.each_cell()])
print("Top Cells:", [c.name for c in source_layout.top_cells()])
print("All Layers:", source_layout.layer_infos())
print()
target_layout = pya.Layout()
target_layout.dbu = dbu
for source_cell in source_layout.each_cell():
print('Cell:', source_cell.name)
print(2*' ', 'Childs:', source_cell.child_instances())
print(2*' ', 'Children:', list(set([inst.cell.name for inst in source_cell.each_inst()])))
target_cell = target_layout.create_cell(source_cell.name)
for inst in source_cell.each_inst():
print(4*' ', 'Instance:', inst.cell.name, inst.cplx_trans, inst.a, inst.b, inst.na, inst.na)
target_cell.insert(inst)
# in every layer after swapping copy shapes from source_layout to target_layout
nr_shapes = 0
for source_lay in source_layout.layer_indexes():
# get source_shapes of layer
source_shapes = source_cell.shapes(source_lay)
nr_shapes += source_shapes.size()
# original layer_no, datatype_no
layer_no = source_layout.layer_infos()[source_lay].layer
datatype_no = source_layout.layer_infos()[source_lay].datatype
# retrieve (create if not existing) target_layer with swapped datatype_no vs. layer_no
target_layer = target_layout.layer(datatype_no, layer_no)
# prepare empty target_shapes
target_shapes = target_cell.shapes(target_layer)
# copy all source_shapes to target_shapes
target_shapes.insert(source_shapes)
print(2*' ', 'Shapes found', nr_shapes)
return target_layout
Regards Robert
Hi Robert,
thanks for sharing this.
You can also modify the layer info to achieve this results if you want to swap layer/datatype for all cells globally:
Hi Matthias
Well, life can be so easy if you know what you are doing .
On the other hand doing it the "hard way" I learned much about traversing the Layout structure.
One small typo in your code: you must either use "ly" or "source_layout" (not intermixing both)
Thank you so much for your reply.
Congratulations for excellent KLAYOUT.
Sure, thanks (for the kudos and the typo note) I have edited the code above.
