Can I run DRC in batch mode?
Can I run DRC in batch mode in linux? What is the command? Where can I find the related info.?
  • Maybe you have an answer from that discussion :
    https://www.klayout.de/forum/discussion/comment/4953
  • Because this question is asked quite often ... Here is the idea:
    You can basically run a DRC script in batch mode this way:
    klayout -b -r your.drc
    In the script you need to tell KLayout where to read the layout from and where to write the report:
    # your.drc:
    source("my_layout.gds")
    report("Description", "my_report.lyrdb")
    As you probably don't want to write a special script for every file, you can pass the input layout's name and the report file name by defining variables with the "-rd name=value" option:
    klayout -b -rd input=my_layout.gds -rd report=my_report.lyrdb -r your.drc
    In the script you refer to these variables with "$input" and "$report":
    # your.drc:
    source($input)
    report("Description", $report)
    Finally, if you want you script to be useful in GUI and batch mode you can put in an "if" which takes these variables only if set on the command line:
    # your.drc:
    if $input
      source($input)
    if $report
    else
      report("Description")
  • Thanks Matthias, Very clear and useful comment.
  • After ran the batch mode with the command : klayout -b -r test.lydrc
    I've got the ERROR message, while test.lydrc run in GUI perfectly. Does anyone know what happen. Thanks.
  • You shouldn't call the file ".lydrc". This suffix is reserved for XML-style scripts.
    ".drc" is the right suffix for plain text files.
  • Got it. Just try to rename and run. It's work now. Many Thanks Matthias
