Hi Sir,
Is it possible to check if L1 with 2 polygon on L2 ?
such as "shape=mesh_line_a.pull_interacting(Layer2)" , but I want to add more condition as below figure.
DRC for at least 2 contacts/vias : https://www.klayout.de/forum/discussion/408/drc-via-spacing-within-a-array-of-vias-number-of-gate-contacts
Hi Laurent
Thanks for your code... but may I know that how to using that code?
I am a new user for Klayout and Ruby...
Hi Laurent
I got the way to running that code..
but it can't working cause that is not a array shape.(it is just some of polygon)
you can check with picture to find what the pattern do I have...
Here is an exemple of contact over Poly
Hi Laurent
could you please help it....
(when I run this DRC function , I get a message ..".No layout loaded. , no default layout..."
then , even I just input a layer or run another DRC code , I still get same message..
Hi Laurent,
I find answer !!! Thanks very much for your help~
