when I have an array of shapes and ask shapes[i].is_polygon? or any of the other .is_???, I usually get true or false.
However, when I pass the array of shapes through a ShapeProcessor, the resultshapes[i].class.to_s still says RBA::Polygon, but resultshapes[i].is_polygon? hangs up the code. Getting the ShapeProcessor to merge already required a strange shape re-collecting. Below is the merge function with the shape processor in it. Do you have a better suggestion on how to implement this ? s1 are shapes of 1 layer, and I would like to merge them no matter what they are (except text of course). The code also worked the same way without the Polygon::new re-assembly after merge. After that, I pass it on to other functions that call .is_xxx? and that is where it sours. If exlude this mergeShapes(s1) function, everything runs fine.
I know this isn't a lot of information go by, but if you have a suggestion that would help me already.
Thank you !
Thomas.
def mergeShapes(s1)
retVal = []
if s1.size>0
shapes = []
s1.each do |shape|
shapes << shape
ep = RBA::ShapeProcessor::new
begin
newshapes = ep.merge_to_polygon(shapes, 0, true, true)
newshapes.each do |newshape|
retVal << RBA::Polygon::new(newshape)
rescue => ex
puts "MERGE FAILED: " + ex.to_s
retVal = s1
else
retVal = s1
return retVal
I need to explain a basic concept here:
In KLayout, there is a "Shape" object and then there are "working objects" (Polygon, Path, Box, ...).
A "Shape" is a geometrical object living inside the database (the "Layout" object). You can think of "Shape" as a pointer. When you manipulate a Shape object, you directly change the layout. When you retrieve geometry from the layout, you will see Shape objects. Shape objects are polymorphic. Then can be polygons, boxes etc. Shape has "is_polygon?" to tell you whether it is a polygon.
The "working objects" are "free": they are not bound to the database. A Polygon is always a polygon, hence it does not need a "is_polygon?" method.
The ShapeProcessor processes Shapes - i.e. it takes them directly from the database. It's output will consist "free" polygons. Hence, the input is Shape, the output is Polygon.
So yes: the type of the shape changes.
Gotcha ! This did the trick. Thank you !!!
