Hallo Matthias,
I downloaded the klayout tarball and try to compile on centos8 and ubuntu -- it worked on centos7 the previous time.
GCC, QT and anaconda python is installed. The make was done with the anaconda qmake - I always use the anaconda installation.
The compilation took some hours and I followed the procedure as with the previous release.
What do I miss? Probably you have an idea.
Andy
Here the error message during the startup:
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Python path configuration:
PYTHONHOME = (not set)
PYTHONPATH = (not set)
program name = '/home/parallels/Downloads/klayout-0.26.8/bin-release/klayout'
isolated = 0
environment = 1
user site = 1
import site = 1
sys._base_executable = '/home/parallels/Downloads/klayout-0.26.8/bin-release/klayout'
sys.base_prefix = '/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho'
sys.base_exec_prefix = '/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho'
sys.executable = '/home/parallels/Downloads/klayout-0.26.8/bin-release/klayout'
sys.prefix = '/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho'
sys.exec_prefix = '/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho'
sys.path = [
'/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho/lib/python38.zip',
'/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho/lib/python3.8',
'/tmp/build/80754af9/python_1599203911753/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho/lib/lib-dynload',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00007f5b30e16780 (most recent call first):
<no Python frame>
(base) parallels@parallels-Parallels-Virtual-Platform:~/Downloads/klayout-0.26.8/bin-release$
Is this pip? Or setup.py?
I get this message when I mess up debug and release versions of Python or when there are multiple Python installations on the system and they are interfering - specifically Python 2 and 3.
Fresh setup on Centos 8, new python anaconda distribution. Python itself works standalone. Klayout see the correct Python installation starting the compilation. Thanks Matthias
Very good!
I'm only using Docker now. Start with a pristine basic Docker image, install just what you need and you'll never run in such trouble
Hello Matthias - I just tried a docker using a cpmplete Ubuntu release. I'm pretty convinced that this is the right direction into future devlopment. In an ideal case you setup a complete project env in a container and copy one for each user. I finally just set the python path and my compiled klayout works perfect.
Thanks for such a great tool and incredible good support.
Andy
Hi Andy,
Yes, docker deployment is actually an option. Being made for web service deployment, Docker provides a too little support for native GUI applications to my taste, but it's perfect for build system maintenance and automation tasks.
