Thought I would share my latest trip down the rabbit hole with Ruby,
prototype power mesh, still needs work too assign the VDD/VSS and correct via placements.
This is base on your Si4all - Dummy PDK
Feel free to comment add suggestions.
Figured out the backticks
#Tracy Groller
#Power Mesh
#Date 2/13/21
#Expermintal Best
def power_mesh
include RBA
app = Application.instance
# Get a handle on the main window and the current view
mw = app.main_window
lv = mw.current_view
if lv == nil
raise "No view selected. Choose File > New layout, and run this again."
# Get a handle on the layout
dbu = ly.dbu
cell = lv.active_cellview.cell
#Define Layer
layer_number = 5
datatype = 0
layer_info = LayerInfo.new(layer_number,datatype)
layer_index = ly.layer(layer_info)
# Define the coordinates
space = 150
wdt = 50
pt1 = 0 #x1
pt2 = 0 #y2
pt3 = 5000 #x2
pt4 = 0 #y2
#steps in the X
for i in 0..25
pts = [RBA::Point.new(pt1/dbu,pt2/dbu),RBA::Point.new(pt3/dbu,pt4/dbu)]
layer_info = LayerInfo.new(9,0)
path = Path.new(pts,wdt/dbu)
cell.shapes(layer_index).insert(path)
pt2 += space #step Y
pt4 += space #step Y
#step in Y define some math
len = pt3/space
pt1 = 0
pt2 = 0 - wdt + 2.5
pt3 = 0
pt4 = pt4 - space + 2.5
for i in 0..len
layer_info = LayerInfo.new(11,0)
pt1 += space #step Y
pt3 += space #step Y
lv.add_missing_layers
def overlap_intersect
if lv == nil
raise "Overlaps InterSect: No view selected"
# start transaction for "undo"
lv.transaction( "Overlaps InterSect" )
begin
# because objects might be referenced multiple times (thru different hierarchy paths)
# we must first copy and then delete them
input_polygons = []
layer_number = 10
datatype = 0
output_layer = layer_index
shape = sel.shape
if shape.is_path? || shape.is_box? || shape.is_polygon?
# Save "area type" shapes in the selection to polygons and delete them
input_polygons.push(RBA::Polygon::from_dpoly(shape.polygon.transformed_cplx(sel.trans)))
cv = lv.cellview(sel.cv_index)
source = cv.layout.cell(sel.cell_index)
#source.shapes(sel.layer).erase(shape)
# Remember the input layer for the output
output_layer ||= sel.layer
if input_polygons.size > 0
# perform the "overlaps to void" operation
# first step: detect overlaps
ep = RBA::EdgeProcessor::new
overlaps = ep.merge_to_polygon(input_polygons, 1, false, false)
# second step: remove the overlaps from original
result = ep.boolean_to_polygon(input_polygons, overlaps, RBA::EdgeProcessor::mode_and, true, false)
# write the result to the output
output_cv = lv.cellview(lv.active_cellview_index)
target = output_cv.cell.shapes(output_layer)
result.each { |p| target.insert(p) }
ensure
# always execute that code:
# commit transaction
lv.commit
# clear selection and cancel all other edit operations, so
# nothing refers to shapes that might have been deleted.
lv.cancel
def resize_layer
#Resize Layer
# Enter your Ruby code here
include RBA
view = mw.current_view
ly = view.active_cellview.layout
cl = view.active_cellview.cell
dbu = ly.dbu
layer_info = LayerInfo.new(5,0)
width = 25000
height = 25000
cl.each_shape(layer_index) do |shape|
if shape.is_polygon?
#Convert polygon to Box
box = shape.bbox
puts("Processing ...")
# puts box.center
# puts box.width
# puts box.height
# puts box.p1
# puts box.p2
# Get Box lx,ly,ux,uy
# puts box
lx = box.left
ly = box.bottom
ux = box.right
uy = box.top
mid = box.left + box.width/2
tid = box.top - box.width/2
box.left = mid - width/2
box.right = mid + width/2
box.top = tid + width/2
box.bottom = tid - width/2
shape.box = box
#Create Power Mesh
power_mesh
#Select All
mw.menu.action("edit_menu.select_menu.select_all").trigger
#edit_menu.select_menu.select_all
#Get Overlap InterSect
overlap_intersect
mw.menu.action("edit_menu.select_menu.unselect_all").trigger
#Resize InterSect
resize_layer
Very good
Much better with the backticks.
But there is an excess one in the line after "include RBA"
Ahhh , just now saw that thanks
Matthias,
Update to process the vias this needs too be cleaned up with respect to the Global definitions and other things as well
Still Learning ... Baby Steps.
As its works like I want, there is probably a better way
Just a thought for all of you out there
If you want to be a EDA programmer, you should be willing to be the dumbest person in
the room and embarrass yourself as a noob.
And you know what, that’s how we improve ourselves.
I don’t want to be the smartest person in a room.
That’s the wrong room for me. I want to be surrounded only by smarter people.
@tagger5896 I agree with your approach. But then, who are the people then who play the smarter ones?
In general, EDA programming isn't much different from many other fields of programming. It's just that EDA tool coding usually isn't taken to a level where skill makes a difference. EDA users are often content with small scripted solutions that make their life easier. But this thinking bears risks. I've seen projects growing from tiny scripts to monsters beyond maintenance. Real software engineers will try to avoid this at every cost - the keywords being refactoring, architecture and design, continuous integration, test driven development style and so on. EDA programmers often seem to consider this overhead, but it's really worth thinking about a test strategy for example right from the beginning. With this in mind EDA programming should be quite similar to other fields of domain specific coding.
And maybe with this standard in mind, popular EDA tools might finally offer coding platforms which are better than last millenium style.
Matthias,
I agree ..
