Filling tool using Python
I want to use the filling tool in my Python script and for that, I need to translate the following script from Ruby to Python. I have problem with the While loop. Any suggestions?
r = ...        # region to fill
c = ...        # cell in which to produce the fill cells
fc_index = ... # fill cell index
fc_box = ...   # fill cell footprint
fill_margin = RBA::Point::new(0, 0)   # x/y distance between tile cells with different origin
# Iteration: fill a region and fill the remaining parts as long as there is anything left.
# Polygons not worth being considered further are dropped (last argument is nil).
while !r.is_empty?
  c.fill_region(r, fc_index, fc_box, nil, r, fill_margin, nil)
  • Hi, Mo!
    I think while not r.is_empty() is correct translation to Python. Similar to other methods with question mark.
  • @EugeneZelenko
    Many thanks for your help. That solved the while issue but for some reason still the filling does not work!!
     fc_box = pya.DBox(...)   # fill cell footprint
        fill_margin = pya.DPoint(self.channel_pitch, 0)   # x/y distance between tile cells with different origin
        region = pya.Region(box8(self.metalrf))
        while not region.is_empty():
          fillshape = self.cell.fill_region(region, circle, fc_box, False, amcp_cell_4, fill_margin, False)
          self.cell.shapes(self.metalrf_layer).insert(fillshape)
  • Isn't None Python equivalent of nil?
  • @MoBe @EugeneZelenko is right. You should use "None" instead of "False".
    But there are more issues:
    • DBox isn't the right version for fc_box. Use Box and use DBU coordinates. Same for fill_margin which should be a Vector and use DBU coordinates.
    • "while not region.is_empty():" doesn't make a lot of sense: the region is not modified, hence, while will never terminate
    • "fill_region" does not return anything, so "fillshape" will be undefined
    Make sure that "circle" is a cell index. "amcp_cell_4" needs to be a Region and will receive the remaining parts.
  • edited March 2021
    Thanks very much for your support @Matthias @EugeneZelenko
    @Matthias I understood the first point you made. But I still don't understand how I can fix the while loop so that it will terminate and how I should define "circle" in a way that I can correctly call it on the "fill_region" function. Here is how I defined it.
    n = 200    # number of points
        r = self.channel_radius*1000  # radius
        da = 2 * math.pi / n
        pts = []
        for i in range(0, n):
          pts.append(pya.Point.from_dpoint(pya.DPoint(r * math.cos(i * da), r * math.sin(i * da))))
        circle = pya.Polygon(pts)
        self.cell.shapes(self.metalrf_layer).insert(circle)
    Thank you again for the amazing support here.
  • edited March 2021
    MoBe
    I think this is what you after .. ;) :)
    I don't know what your channel_radius is
    so just plugged in a number
    Tracy
    import pya import array import sys import math layout = pya.Application.instance().main_window().current_view().active_cellview().layout() if layout == None: raise Exception("No layout") cv = pya.Application.instance().main_window().current_view().active_cellview() dbu =layout.dbu cell = pya.Application.instance().main_window().current_view().active_cellview().cell if cell == None: raise Exception("No cell") n = 200 # number of points r = 2*1000 # radius da = 2 * math.pi / n def coords(path): result = [] for p in path: result.append(DPoint.new(p[0]/dbu,p[1]/dbu)) return result def create_polygon(crd,lay): layer_info = LayerInfo.new(lay,0) layer_index = layout.layer(layer_info) cv.cell.shapes(layer_index).insert(Polygon.new(crd)) circle = [] for i in range(0, n): path = r * math.cos(i * da), r * math.sin(i * da) circle.append(path) lay = 9 pth = coords(circle) create_polygon(pth,lay)
  • edited March 2021
    @tagger5896 Thanks for the codes. I already defined the circle and it works as it is supposed to. However, the problem is I don't understand in the above scripts, how I should call the circle in the "fill_region" function correctly and how I can stop the loop. Basically, I don't understand the "unsigned int fill_cell_index" written in the documentation for fill_region:
    Signature: void fill_region (const Region region, unsigned int fill_cell_index, const Box fc_box, const Point ptr origin, Region ptr remaining_parts, const Vector fill_margin, Region ptr remaining_polygons)
    Description: Fills the given region with cells of the given type (extended version)
    region: The region to fill
    fill_cell_index:    The fill cell to place
    fc_box: The fill cell's footprint
    origin: The global origin of the fill pattern or nil to allow local (per-polygon) optimization
    remaining_parts:    See explanation below
    fill_margin:    See explanation below
    remaining_polygons: See explanation below
    Another point is what I am trying to build is a PCell, and I don't want to make another cell within my PCell (I am not sure if that is even possible). So, basically, I should make the circle within the Pcell and call it in fill_region function. Hope this makes sense!
    Thanks again.
  • The fill_cell_index is the cell.cell_index() where cell is the pya.Cell object you want to use for filling. And of course it is possible to instantiate other cells within a PCell, where would the fun be without that possibility ;) (you can even instantiate other PCells within a PCell, although I had to bother Matthias a long time until I understood how to do that ^^).
  • @sebastian Thank you for your help. Really appreciate it. However, nothing worked for me to translate the following into python codes, although I was able to do it some other way it is extremely slow because of the loops that it contained! If anyone has an idea, that would be much appreciated!
    while !r.is_empty?
  • Hello @MoBe
    You should specify the starting point (instead of nil) to make the fill_region work correctly:
    region     = db.Region(db.Box(x_start,y_start,x_end,y_end))
                    topcell_o.fill_region(region, input_topcell.cell_index(), db.Box(input_bbox), db.Point(x_start,y_start), region, db.Point(0.0,0.0), None)
    The last argument could be set to 'None'.
