Utilizing the following code below would like to use a Path instead,
I have not have had good result's , would line the marker to follow the path
Example box code below, would like too follow path ...
ideas comments
# Enter your Python code here
# Register this macro as "autorun" to enable the plugin
# This is the plugin implementation
class DragBoxPlugin(pya.Plugin):
def __init__(self, view):
super(DragBoxPlugin, self).__init__()
self.marker = None
self.box = None
self.start_point = None
self.view = view
def activated(self):
pya.MainWindow.instance().message("Click on point to start dragging a box", 10000)
def _clear_marker(self):
if self.marker is not None:
self.marker._destroy()
self.marker = None
def _update_marker(self):
if self.marker is None:
self.marker = pya.Marker(self.view)
self.marker.line_style = 2 # short-dashed
self.marker.vertex_size = 0 # no vertexes
self.marker.set(self.box)
def deactivated(self):
self._clear_marker()
pya.MainWindow.instance().message("", 0)
if prio:
self.box = pya.DBox(p, p)
self.start_point = p.dup() # Note dup() which creates a copy we can store
self._update_marker()
self.grab_mouse()
pya.MainWindow.instance().message("Drag the box and click again", 10000)
else:
self.ungrab_mouse()
self.box_finished(self.box)
return True
return False
def box_finished(self, box):
# TODO: put in your code to do what you like to do with the box
pya.MainWindow.instance().message("Box finished: " + str(box), 10000)
b = str(box)
c = re.split('[ ; , ) (]', b)
#Get Box Coordinates
x1 = c[1]
y1 = c[2]
x2 = c[3]
y2 = c[4]
print(f"x1:y1 = {x1},{y1} : x2:y2 = {x2},{y2} ")
def mouse_moved_event(self, p, buttons, prio):
if prio and self.marker is not None:
self.box = pya.DBox(self.start_point, p)
return True
return False
# Implement a "plugin factory".
# This object is asked to provide a plugin for each view
class DragBoxPluginFactory(pya.PluginFactory):
def __init__(self):
super(DragBoxPluginFactory, self).__init__()
self.has_tool_entry = True
self.register(-1000, "drag_box", "Drag Box")
return DragBoxPlugin(view)
# Keeps the singleton instance
instance = None
# Create and store the singleton instance
DragBoxPluginFactory.instance = DragBoxPluginFactory()
I'm not sure if I understand the problem.
should also work if you set a DPath object instead of a DBox.Doesn't it?
Matthias,
Sorry the DragBox works as expected,
I would like to be able to use a Path and follow the mouse clicks,
instead of drawing a box it would draw a path .
that make sense ...
I have tried the DPath Object , I may be missing something or
just not able to wrap my head or mouse around this
@Matthias
Revisiting this thread as suggest I made changes this does not work like the Box
self.marker.set(self.box) should also work if you set a DPath object instead of a DBox.
Doesn't it?
I am missing something ....
