So I am using the following code I came up with the import GDS files,
it uses a GUI to select the files ..
All works well the first time ,
but when you run the script again ,
to select new cells .
it loads the previous cells as well.
issue seems to be with the tc = layout.top_cells()
for cell in gdsFiles:
layout.read(cell)
for cell in tc:
#we don't want to insert the topcell itself
if (cell.name != "TOP"):
print('New Cell generated: '+cell.name+' in Hierarchy '+topcell.name)
trans = pya.CplxTrans( 1.0, ang, flip, x, y)
new_instance=pya.CellInstArray.new(cell.cell_index(),trans)
print(trans)
layout.cell(top_cell_idx).insert(new_instance)
x = x + step
This is weird. Basically after you have inserted the cell instances, "layout.top_cells" should give you only a single cell.
You can print the number of top cells after the loop to verify this.
You should also check if:
@Matthias
I have done this above as a debug.
There is some Ruby code in the fourms that does a similar thing .
https://www.klayout.de/forum/discussion/735/merge-multiple-gds-files-to-one-parent-cell#latest
it's not an issue just something I noticed
Tracy
