We are trying to merge some database files or boolean layers, however sometimes this kind of action would cause klayout crash and show "Segmentation fault". According to the message it should be the bug of ruby library, we tried to upgrade the ruby library version from p249 to p334, but the problem is still there, could you please help to confirm what happened ? thanks for your kindly support~
QPaintEngine::setSystemClip: Should not be changed while engine is active
QWidgetPrivate::beginSharedPainter: Painter is already active
QPainter::begin: A paint device can only be painted by one painter at a time.
[BUG] Segmentation fault
ruby 1.8.7 (2010-01-10 patchlevel 249) [x86_64-linux]
After upgrade ruby version, all the error messages are the same.
ruby 1.8.7 (2011-02-18 patchlevel 334) [x86_64-linux]
Best Regards,
chhung
Hi chhung,
The error message is not related to Ruby, although the message may suggest that. Ruby is not responsible for that problem, it just happens to register a signal handler for the segmentation fault. Also the warnings you mentioned are likely not to be the cause of the problem.
It's actually somewhat hard to track down what is the cause of the problem. There are some things you could try
I spent some time to confirm the strange problem and sorry to reply so late.
Although the ruby version has been upgraded from 1.8.7 p334 to 1.9.3 p194, the segmentation fault issue is still there. The most unbelievable thing is the situation would happen randomly, the same operation steps may success this time, however fail next time.
To upgrade gcc version is a bit difficult on our system, I'll try to compile the snapshot version for the new scanline algorithm, really appreaciate your kindly support.
Much more info was generated with ruby 1.9.3 p194, I have no idea if it helps and will paste some here.
-e: [BUG] Segmentation fault
ruby 1.9.3p194 (2012-04-20 revision 35410) [x86_64-linux]
-- Control frame information -----------------------------------------------
c:0001 p:0000 s:0002 b:0002 l:000c38 d:000c38 TOP
-- C level backtrace information -------------------------------------------
/usr/local/klayout/lib64/test/libruby.so.1.9(rb_vm_bugreport+0x82) [0x7fc27a3f6542]
/usr/local/klayout/lib64/test/libruby.so.1.9 [0x7fc27a3049b4]
/usr/local/klayout/lib64/test/libruby.so.1.9(rb_bug+0xa9) [0x7fc27a304a89]
/usr/local/klayout/lib64/test/libruby.so.1.9 [0x7fc27a39b8c7]
/lib64/tls/libc.so.6 [0x7fc2784d7b60]
/usr/local/klayout/lib64/test/libQtGui.so.4(_ZNK8QPainter8isActiveEv+0x11) [0x7fc2799d7371]
/usr/local/klayout/lib64/test/libQtGui.so.4(_ZNK8QPainter8clipPathEv+0x35) [0x7fc2799d8dd5]
many messages about Qt4 and Glib........
/lib64/tls/libc.so.6(__libc_start_main+0xda) [0x7fc2784c54fa]
/usr/local/klayout/bin64/test/klayout(_ZNSsC1ERKSsmm+0x3a) [0x7d3e1a] ../sysdeps/x86_64/elf/start.S:113
-- Other runtime information -----------------------------------------------
* Loaded script: -e
* Loaded features:
0 enumerator.so
1 /usr/lib64/ruby/1.9.1/x86_64-linux/enc/encdb.so
2 /usr/lib64/ruby/1.9.1/x86_64-linux/enc/trans/transdb.so
3 /usr/lib64/ruby/1.9.1/rubygems/defaults.rb
4 /usr/lib64/ruby/1.9.1/x86_64-linux/rbconfig.rb
5 /usr/lib64/ruby/1.9.1/rubygems/deprecate.rb
6 /usr/lib64/ruby/1.9.1/rubygems/exceptions.rb
7 /usr/lib64/ruby/1.9.1/rubygems/custom_require.rb
8 /usr/lib64/ruby/1.9.1/rubygems.rb
9 /usr/lib64/ruby/1.9.1/x86_64-linux/stringio.so
* Process memory map:
00400000-01836000 r-xp 00000000 00:11 805743154 /usr/local/klayout/bin64/test/klayout
01935000-01967000 rw-p 01435000 00:11 805743154 /usr/local/klayout/bin64/test/klayout
01967000-2e07b000 rw-p 00000000 00:00 0 [heap]
405c8000-405c9000 ---p 00000000 00:00 0
etc.....
[NOTE]
You may have encountered a bug in the Ruby interpreter or extension libraries.
Bug reports are welcome.
For details: http://www.ruby-lang.org/bugreport.html
Best Regards,
chhung
I tried to compile the klayout-r1335 with all the same setting to compile klayout v0.21.19, however failed with the following error, could you please let me know how to fix the problem? Thanks~
/source/klayout-r1335/src/layGenericSyntaxHighlighter.cc:593: error: no matching function for call to `QRegExp::capturedTexts() const'
/usr/lib/qt4/include/QtCore/qregexp.h:113: note: candidates are: QStringList QRegExp::capturedTexts() <near match>
/source/klayout-r1335/src/layGenericSyntaxHighlighter.cc:594: error: no matching function for call to `QRegExp::capturedTexts() const'
make[1]: *** [layGenericSyntaxHighlighter.o] Error 1
Best Regards,
chhung
Hi chhung,
Apparently Qt switched to a const version of capturedTexts somewhere between Qt 4.2 and 4.5. You can fix the compile problem by using a const cast in line 593 and 594:
Replace
with
Hope that helps. I will check the build against some older Qt version before I release it.
I modified the capturedTexts section in layGenericSyntaxHighlighter.cc, and encountered other problems.
rba.cc:
/source/klayout-r1335/src/rba.cc: In member function `void rba::GetBoxValueFunc::op()':
/source/klayout-r1335/src/rba.cc:1250: error: expected primary-expression before '>' token
/source/klayout-r1335/src/rba.cc:1250: error: expected primary-expression before ')' token
make[1]: *** [rba.o] Error 1
It's caused by the following codes, however I don't know where the error is~
if (bo) {
mp_ret = bo->value ().morph<R> ().native_ptr ();
layMacroEditorPage.cc:
/source/klayout-r1335/src/layMacroEditorPage.cc: In member function `void lay::MacroEditorPage::breakpoints_changed()':
/source/klayout-r1335/src/layMacroEditorPage.cc:434: error: 'class QTextBlock' has no member named 'firstLineNumber'
/source/klayout-r1335/src/layMacroEditorPage.cc: In member function `void lay::MacroEditorPage::text_changed()':
/source/klayout-r1335/src/layMacroEditorPage.cc:454: error: 'const class QTextBlock' has no member named 'firstLineNumber'
/source/klayout-r1335/src/layMacroEditorPage.cc: In member function `void lay::MacroEditorPage::ensure_line_visible(int)':
/source/klayout-r1335/src/layMacroEditorPage.cc:511: error: 'class QTextBlock' has no member named 'firstLineNumber'
Best Regards,
chhung
Hi chhung,
what gcc version are you using? It appears to be a pretty old one. Also Qt appears to be an older one.
I'd recommend gcc >=4.3.x and Qt >=4.5.x. I'll try to fix it for Qt >=4.2.x - that is the oldest version for which that makes sense.
Our gcc version is 3.4.3 and Qt is 4.4.3, I know it's very old but we have to keep it running.
I tried to setup a CentOS(RHEL) 6.2 with gcc 4.4.6 and Qt 4.6.2, it could be used to compile either 0.21.19 or r1335 well, however the compiled binary code could not work on our old workstation because of the glibc blahblah library problem.
I'll look for a way to install newer gcc version on our Mandrake Linux workstation and try to compile the code again, thanks for your kindly help~
Best Regards,
chhung
