Hi sir ,
in the polygon layer (as below code sampe), I want to check which pattern that area more than spec (as the value in ruleParea )
and copy that pattern to layer 500,0.
here is my code , I think that code have some mistake.
could you please help it?
Thanks.
RDL=input(154,0)
ruleI=25
ruleParea=5735
AreaX =
RDL.merged.each do |p|
if p.area>5735
AreaX << p
AreaX.output(500,5)
You should use
Got it . Thanks
