Sorry to disturb you again, currently the klayout Windows version did not enable the wide coordinates option,
is it possible to enable it in next release ? We tried the latest version (even 0.27.1) and got the "Unsigned integer value overflow"
with some large precision db.
Really appreciate your kindly response, thank you.
chhung
@phlion As wide coordinates take twice as much memory I have not enabled them by default and it's still kind of experimental. So far I have not seen many requests for wide coordinates.
You can find regular builds of the master branch including 64bit coordinate support here: https://www.klayout.org/downloads/master/
The current build with 64bit coordinate is this: windows/klayout-0.27.1-win64-c64-install.exe
Please note that even though these builds are called after a specific version, they are snapshots taken from the development branch. The binaries are also unsigned, so use them at your own risk.
Really thanks for your quickly response, we tried this program "klayout-0.27.1-win64-c64-install.exe" , and it fixed the "Unsigned integer value overflow" problem we encountered.
Thank you so much~
chhung
Very good
I have initiated standard builds for wide coordinates on Windows. I do not recommend using them, but I'll try to make them available for download for future releases.
