Is it possible to fill a KLayout dialog from RBA?
For some DRC automation job, I would like to open the Marker Browser dialog from ruby (which can be done by triggering the menu item) and fill the Database field.
it is possible to create a marker database by script and show the marker browser dialog with that marker database.
I have added a sample script that demonstrates how to create, fill and show a marker database. In that script the database is filled from the shapes on the currently selected layer.
def scan_layers
mw = app.main_window
view = mw.current_view
return unless view
layers = view.selected_layers
return unless layers.size > 0
cv_index = -1
view.selected_layers.each do |l|
if cv_index >= 0
if l.current.source_cellview(true) >= 0 && cv_index != l.current.source_cellview(true)
raise "Selected layers must originate from the same layout"
else
cv_index = l.current.source_cellview(true)
cv = view.cellview(cv_index)
return unless cv.is_valid?
layout = cv.layout
dbu_trans = RBA::DCplxTrans::new(layout.dbu)
rdb_index = view.create_rdb("layer_scan")
rdb = view.rdb(rdb_index)
rdb.top_cell_name = layout.cell_name(cv.cell_index)
cells = {}
layout.each_cell do |cell|
cells[cell.cell_index] = rdb.create_cell(layout.cell_name(cell.cell_index))
if cv_index == l.current.source_cellview(true)
layer_index = l.current.layer_index
if layout.is_valid_layer?(layer_index)
cat_name = l.current.source(true)
rdb_cat = rdb.create_category(cat_name)
rdb_cat_id = rdb_cat.rdb_id
rdb_cell = cells[cell.cell_index]
rdb_cell_id = rdb_cell.rdb_id
cell.shapes(layer_index).each do |shape|
if shape.is_polygon? || shape.is_path? || shape.is_box?
rdb_item = rdb.create_item(rdb_cell_id, rdb_cat_id)
dpoly = RBA::DPolygon::from_ipoly(shape.polygon).transformed_cplx(dbu_trans)
value = RBA::RdbItemValue::new(dpoly)
rdb_item.add_value(value)
# Hint: a corresponding cm_... method is missing
action_path = "tools_menu.browse_markers"
if mw.menu.is_valid(action_path)
mw.menu.action(action_path).trigger
# A helper class for a menu bound action
self.title = title
self.shortcut = shortcut
@action = action
def triggered
@action.call( self )
private
@action
# register the function in the toolbar
# TODO: add shortcut, correct title etc.
menu = mw.menu
menu.insert_separator("@lcp_context_menu.end", "tb_separator")
menu.insert_item("@lcp_context_menu.end", "scan_layers", MenuAction.new("Scan Layers Into RDB", "") { scan_layers })
Hallo,
