How to Clear the DRC template layer
PI1.inside(DIE).output(51,1000)
PI1_IO=input(51,1000)
PI1.not_inside(DIE).output(51,1001)
PI1_edge=input(51,1001)
PI2.inside(DIE).output(56,1000)
PI2_IO=input(56,1000)
PI2.not_inside(DIE).output(56,1001)
PI2_edge=input(56,1001)
###check RuleL ####
as this DRC code , we have to make some template layers during DRC .
after rule check , how to remvoe /clear these templete layers (by DRC code).
I have try the way as below , but it is not work....
PI2_IO.not(PI2_IO).output(56,1000)
PI2_edge.not(PI2_edge).output(56,1001)
  • @jiunnweiyeh You do not need to generate output layers if you do not need the layer later.
    Instead of
    you simply say
    PI1_IO = PI1.inside(DIE)
    to save some memory you can delete a layer once you do not need it anymore using "forget":
    PI1_IO.forget
    Thanks a lot for your help.
    Is it possible to using this code?
    (I want to remove layer 86,0)
    ####clear layers#####
    layer(86,0).forget
  • edited June 2021
    No. "forget" only frees memory of a temporary layer.
    If you want to clear a layer in a DRC script, you can write an empty layer to it:
    polygons.output(86, 0)
    please let ms explain more detail, as this code
    PI1_io=input(86,0)
    ruleParea=500
    ruleP=50
    PI1_io.with_area(0.um .. ruleParea).output("PI1_io")
    PI1_io_small = input("PI1_io")
    PI1_io_large = PI1_io.without_area(0.um .. ruleParea)
    PI1_io_large = input("PI1_io_large")
    PI1_io_large.separation(PI1_io_small,ruleP.micron).output("RuleP")
    this code is workable , out it will output 2 new layer , 1 is "PI1_io" , another 1 is "PI1_io_large"
    when I change the code as below...
    PI1_io=input(86,0)
    ruleParea=500
    ruleP=50
    PI1_io_small = PI1_io.with_area(0.um .. ruleParea)
    PI1_io_large = PI1_io.without_area(0.um .. ruleParea).
    PI1_io_large.separation(PI1_io_small,ruleP.micron).output("RuleX")
    it is not workable , and output a error message .
    this is why I want to using the code 1 for DRC .
    and , cause I will output addtion template layer , in this case , it is "PI1_io_large" and "PI1_io_small"
    these layers will make some confuse in designer , it is why I want to remove or empty the both layers.
    even I copy a empty layer as your code
    polygons.output("PI1_io_small")
    I still can't make the both layers been empty..
    could you please help it?
    Thanks.
  • @jiunnweiyeh There is an additional dot at the end of this line:
    This will make the parse think there is a method following :)
