Hi there,
I'm wondering if I am overlooking something with trying to search for a text field in a cell that contains "[]" for vector notation.
The query I am using to search for the specific text string is the following:
texts on layer / from cells * where shape.text_string ~ "PS[1]" //this does not return anything even if I have a text_string of those characters.
texts on layer / from cells * where shape.text_string ~ "PS*" //returns in the results box text('PS[1],...)
Using version 0.26.7 on windows
Are bracket supported in the search function?
@edwu Brackets indicate character classes in "~" - the glob pattern syntax is borrowed from the Unix shell.
So "PS[123]" is actually "PS1", "PS2" or "PS3". Same for "PS[1-3]".
To really use brackets, you have to use a backslash to escape them - i.e. "PS[1]". Or you use the "==" instead of "~" which does a plain text compare.
Thanks @Matthias
