Statically linked Ruby 1.9.3 won't load any Ruby files
edited August 2012 in KLayout Support
I just compiled klayout against a static libruby (version 1.9.3-p0) and I keep getting the following error:
Ruby error: 'cannot load such file -- hello_world.rb' (LoadError)
Is 1.9.3 not supported? A brief look over the code indicates that it should be supported. Any ideas why this might be happening? Is there any more information I can provide to help debug?
    I ran into the same thing, Matthias gave me the tip to add the following to the .rb script to print the search path
    puts $:
    Statically linked 1.9.3 doesn't have "." in the ruby search path.
    klayout -r ./hello_world.rb
    worked for me.
    Ah, awesome. That got it working for me too. Thanks very much!
    Hi Stefan,
    thanks for the hint regarding statically linked ruby. I did not know that it behaves differently compared to the dynamically linked one.
    Actually, I'm not so sure it's specific to statically linked Ruby. If I'm not mistaken, the entire 1.9 series doesn't have "." in the ruby search path. I tried the dynamically linked ruby after posting the original post and it also did not work.
    Apparently it does not have to do with the linking mode, but they dropped the "." in Ruby 1.9.2. Here is a discussion thread about that: http://stackoverflow.com/questions/4965556/why-isnt-current-directory-on-my-ruby-path.
    The solution appears to set the RUBYLIB environment variable to "." (which adds ".") or specify the script path explicitly. However, lacking a 1.9.2 ruby installation right now I did not test that myself.
