Is there an easy way (method available) to sort the layers in the "Layers" window (RMB > Sort By > Name) by code?
Yes, there is such a way:
pya.MainWindow.instance().call_menu("cm_lv_sort_by_name")
Hello Matthias,
Thank you! It works great...
1) How do you use "menu_symbols" to obtain all symbols?
2) If the "call_menu" pops up a window (like "cm_lv_rename_tab" for example), is there a way to fill in the field and press "OK" by code?
1) It works fine in Python, but I can't make it work in Ruby:
RBA::Application.instance.main_window.menu_symbols
Error > private method `menu_symbols' called for #
2) Ok, good to know
Thanks again...
Ruby version is:
RBA::MainWindow::menu_symbols
and the shorter (and better) Python version (menu_symbols actually is a class method):
pya.MainWindow.menu_symbols()
Hello Matthias,
2) Ok, good to know
Thanks again...
Ruby version is:
