Call DRC function in Ruby
Hi Sir,
I want to create a function in tool bar , and reference to other sample , I make that as below.
But , look like I can't call DRC functin in Ruby , May I know how to do that?
    self.title = title
    self.shortcut = shortcut
    @action = action
  def triggered
    @action.call( self )
private
  @action
$Check_bump_pitch = MenuAction.new( "Check min. bump pitch", "" ) do
  mw = app.main_window
  lv = mw.current_view
  if lv == nil
    raise "No view selected"
# equivalent of "a = input(7, 0)"
layer_a = ly.layer(94, 0)
UBM = pya.Region(ly.top_cell().begin_shapes_rec(layer_a))
layer_b = ly.layer(71, 0)
DIE = pya.Region(ly.top_cell().begin_shapes_rec(layer_b))
ubmcount=0
UBM.each {
ubmcount +=1
minPitch=Array.new
x=0
LayerList=[[0.0,0.0,0.25,0.25],[0.0,0.25,0.25,0.5],[0.0,0.5,0.25,0.75],[0.0,0.75,0.25,1.0] \
                 ,[0.25,0.0,0.5,0.25],[0.25,0.25,0.5,0.5],[0.25,0.5,0.5,0.75],[0.25,0.75,0.5,1.0] \
                 ,[0.5,0.0,0.75,0.25],[0.5,0.25,0.75,0.5],[0.5,0.5,0.75,0.75],[0.5,0.75,0.75,1.0] \
                 ,[0.75,0.0,1.0,0.25],[0.75,0.25,1.0,0.5],[0.75,0.5,1.0,0.75],[0.75,0.75,1.0,1.0]]
LayerList.each { |n|
x1 = n[0].to_f
y1 = n[1].to_f
x2 = n[2].to_f
y2 = n[3].to_f
DIE.extent_refs(x1,y1,x2,y2).output(1000,x)
outline1=input(1000,x)
UBM.interacting(outline1).output(50000,x)
ubm1=input(50000,x)
outputdataX=Array.new
outputdataY=Array.new
pitchValue=Array.new
count=0
  ubm1.each do |obj|
  outputdataX << "#{obj.bbox.center.x.round(3)},#{obj.bbox.center.y.round(3)}"
  outputdataY << "#{obj.bbox.center.x.round(3)},#{obj.bbox.center.y.round(3)}"
 outputdataX.each do |out1|
 point1 = out1.split(",")
 xvalue1 = point1 [0]
 yvalue1 = point1 [1]
 outputdataY.each do |out2|
 point2 = out2.split(",")
 xvalue2 = point2 [0]
 yvalue2 = point2 [1]
 distance=Math.sqrt(( ( xvalue1.to_f - xvalue2.to_f ) *  ( xvalue1.to_f - xvalue2.to_f ))  +  (( yvalue1.to_f - yvalue2.to_f ) *  ( yvalue1.to_f - yvalue2.to_f ) ))
if distance > 0 then
pitchValue << distance.round(3)
minBumppitch = pitchValue.uniq.sort[0]
minPitch << minBumppitch
#puts "Area #{x} ,min bump pitch is #{minBumppitch} ; layer is 50000/#{x}"
x+=1
RBA::MessageBox.info("min. Bump pitch", "The min. bump pitch is {minPitch.sort[0]}", RBA::MessageBox.b_ok)
menu = mw.menu
menu.insert_item("tools_menu.end", "Check_bump_pitch", $Check_bump_pitch)
  • You have to use RBA::Region instead of pya.Region. "pya" is Python, "RBA" is Ruby.
    Plus, creating the Region in Ruby is done by using "new":
    I'd also recommend not to use upper-case variable names such as "UBM", because Ruby will treat these variables as constants.
    After change the code as ..
    ly = RBA::CellView.active().layout()
    ubm = RBA::Region(ly.top_cell().begin_shapes_rec(layer_a))
    die = RBA::Region(ly.top_cell().begin_shapes_rec(layer_b))
    I get error message as this one.
    how can I do to debug this issue?
    and , If it is a multi-top cell case , and I just want to process current cell view in script.
    how to do that?
  • In Ruby, you need to call "new" to create a new object. So it's
    ubm = RBA::Region::new(ly.top_cell().begin_shapes_rec(layer_a))
    in both places.
    after change code as..
    currentcellview = RBA::CellView.active().cell()
    ubm = RBA::Region::new(currentcellview.begin_shapes_rec(layer_a))
    die = RBA::Region::new(currentcellview.begin_shapes_rec(layer_b))
    I still get a message as attahced.
    Can you please help it ?
    Thanks.
  • Region#extent_refs is an undocumented method for use in DRC's "extent_refs" implementation. It expects the four relative dimension arguments plus an x and y oversize value. You can set these values to 0 in your case:
    DIE.extent_refs(x1,y1,x2,y2,0,0).output(1000,x)
  • @Matthias
    after change the code , it still get same result...
        self.title = title
        @action = action
      def triggered
    private
      @action
      if lv == nil
    ubmcount=0
    ubm.each {
    ubmcount +=1
    minPitch=Array.new
    x=0
    x1 = n[0].to_f
    y1 = n[1].to_f
    x2 = n[2].to_f
    y2 = n[3].to_f
    die.extent_refs(x1,y1,x2,y2,0,0).output(1000,x)
    ubm.interacting(outline1).output(50000,x)
    ubm1=input(50000,x)
    count=0
      ubm1.each do |obj|
    x+=1
    menu = mw.menu
  • It does not work this way ... "output" isn't a method of the Region class. It's a DRC method. The (flat) equivalent is to insert the Region into a Shapes object like this:
    output_cell.shapes(output_layer_index).insert(region_to_output)
  • @mathine
    Thanks for your answer , I will check it.
    Do you have idea for how to make a cellS inputer?
    As this code , I can enter 1 cell in input only. how to make multi input ?(I have many cells need to process...)
    LayoutView = RBA::Application::instance.main_window.current_view.active_cellview.layout
    dialog = RBA::QDialog.new( RBA::Application.instance.main_window)
    dialog.windowTitle = "Creater"
    layout = RBA::QVBoxLayout::new(dialog)
    dialog.setLayout(layout)
    eachcells = LayoutView.each_cell
    die_list =Array.new()
    eachcells.each do |ly|
      die_list << ly.name
    label =  RBA::QLabel.new(dialog)
    layout.addWidget(label)
    label.text = "Choose DIE cell"
    dieCell =  RBA::QComboBox.new(dialog)
    die_list.each do |subcell|
    dieCell.addItem(subcell)
    layout.addWidget(dieCell)
    dialog.exec
  • @jiunnweiyeh A QComboBox cannot be used to select multiple cells. You'll need a QListWidget for this (https://doc.qt.io/qt-5/qlistwidget.html).
  • @Matthias
    Got it , Thanks your help ,
    as this code , I can choose 1 cell in list only , how can I choose multi cell in the list?
    (even I clicked the cell item with "Shift" key , I still can't select multi -cell in the list....)
    And , how to get the values (cell name list as this case) after we choose that?
    layoutView = RBA::Application::instance.main_window.current_view.active_cellview.layout
    eachcells = layoutView.each_cell
      die_list << ly.name
    dieCell=RBA::QListWidget.new(dialog)
    dieCell.addItems(die_list)
    button1 = RBA::QPushButton.new(dialog)
    layout.addWidget(button1)
    button1.text = "Click there"
    button1.clicked do
    puts dieCell.currentRow  ##
    RBA::QMessageBox::information(dialog, "Message", "#{dieCell.currentRow}")
    dialog.exec
  • You're getting closer .. :)
    You have to enable multi-selection on the list widget:
    dieCell.setSelectionMode(pya.QAbstractItemView.ExtendedSelection)
  • @Matthias
    Here was my code , I can make choose as a list.
    But I can't get the result...I means that I can't get what the cell name been choose.
      die_list << ly.name
    dieCell.setSelectionMode(RBA::QAbstractItemView::ExtendedSelection)
    button1.clicked do
    #puts dieCell.selectedItems
    #puts dieCell.selectionCommand
    #puts dieCell.row
    #puts dieCell.count
    #puts dieCell.itemClicked
    #puts dieCell.currentRow
    puts dieCell.currentItem
    dialog.exec
  • "selectedItems" is the right way ... but you need to collect the "text" attributes.
    Here is an example:
    class MultiSelectionDialog < RBA::QDialog
      def initialize(parent)
        super(parent)
        layout = RBA::QHBoxLayout::new(self)
        list = RBA::QListWidget.new(self)
        list.setSelectionMode(RBA::QAbstractItemView::ExtendedSelection)
        list.addItems([ "one", "two", "three", "four", "five" ])
        layout.addWidget(list)
        @list = list
      def selected_strings
        @list.selectedItems.collect { |item| item.text }
    dialog = MultiSelectionDialog::new(nil)
    dialog.exec
    puts("Selected strings: " + dialog.selected_strings.join(","))
    Got it , Thanks.
