Hello Matthias:
Somehow I lost my top cell after I run below code, not sure the " each_shape " function will erase the cell where it exist ? or I missed something important ?
layout = pya.Application.instance().main_window().current_view().active_cellview().layout()
top = pya.Application.instance().main_window().current_view().active_cellview().cell
pin = layout.layer(95, 0)
label = top.each_shape(pin) <-----
Thanks for your reply always
No, each shape will not erase anything. But the code is lacking the body of the loop. It should look like
Hello Matthias, Thank a lot.
Hello Matthias :
Below is a simple code to centralize the text in box, but I still lost my top cell and text after running. I just made it write a new GDS file to cover temporary. Would you give me some idea when free? Thank you ~
First, "layout" is a variable which is not assigned anything. I think you want to say
Second, the first loop just iterates over the pins and labels in the same loop. I think you want to have two separate loops for collecting pins and labels. This is a simple version using array comprehension:
Third, you can iterate over the arrays themselves, drop the "else" (with the "None" which is simply nonsense) and simplify the inside check:
Hello Matthias,
Wow.. this updated code is amazing to me !! Can't not wait to use this skill to other script.
Somehow, after running the updated code, I still lost my top cell. I think re-location the shape coordinate
pin.text_dpos = pad.dbbox().center()
already means " ... do something with "shape" .. " , but it's OK to re-write a new GDS to cover it, not too much time , thanks a lot
Could you explain what you mean by "lost my top cell"? It's still there - the code does not change that. And when I tried the code I still see the top cell and it's still active.
Hello Matthias,
Maybe it is due to my own computer's problem, please have below 3 pictures,
a) Picture-1 : use box 100 x 200 um to test
b) Picture-2 : top cell is disappear after running below code
c) Picture-3 : choose both text & box by mouse dragging, found the text already be centralized,
I found after the code run, just save file and re-open it, everything will be normal, thanks
Thanks for the images.
This is weird. The cell must be there still, but I don't know why it is not displayed. I have not seen an effect like this before.
What Windows version are you using?
Hmmm..... Windows 7 " professional " SP1 , maybe it is time to upgrade..
Vincent
Oh well, maybe
I'm not aware of any compatibility issues, but maybe it's a graphic driver thing or similar. I guess only the cell name isn't painted. Data is still there.
Got it with thanks
Vincent
