When drawing a path or polygon manually by clicking the left mouse button to add vertices, is there a way to go back one or more vertices in case you made a wrong click somewhere, for instance by pressing the "Backspace" button one or more times? For now, I draw the full polygon or path and edit the wrong vertices afterwards using "Partial" but that can be quite cumbersome...
No, there is no "backspace" yet, but that is a nice suggestion. That should be pretty intuitive.
I created a ticket: https://github.com/KLayout/klayout/issues/1058
Or ^Z, though that might "undo" the whole command?
@Matthias
May I know how to draw a path by Ruby code?
I knew how to create a box in ruby , such as "top.shapes(l1).insert(RBA::Box::new(-10000, 1, 10000, -1))"
but , what code for the path ?
I tried
top.shapes(l1).insert(RBA::Path::new(-10000, 1, 10000, -1))
top.shapes(l1).insert(RBA::Line::new(-10000, 1, 10000, -1))
But it is non workable....
Hi jiunnweiyeh,
A path should have (at least) an array of points and a path width as parameters:
RBA::Path::new([point1, point2, point3, ...], pathwidth)
See also: https://www.klayout.de/doc-qt5/code/class_Path.html
hi @tomas2004
Thanks your reply , I can't make path use following code.. I just make a 1 um path from 0,0 to 15,15.
I guess that , I have to package the coordinate (0,0 15,15) to "spine" format.
But I have no idea how to process that...could you please help it?
Thanks.
Hi jiunnweiyeh,
The points need to be instances of the Point (DBU units) or DPoint (um) class:
@tomas2004
I Got it, Thanks very much for your help.
