Problems with undefined method
I am new to klayout, and am trying to improve my coding skills...
I wish to create a macro that would compute the surface of all selected objects.
However, whenever i use a function from the LayoutView class, I have a message saying me I use an undefined method :
You can see my code on the image, as well as the message I get. Could anyone help me understand my problem ?
Also, with the function on_selection_changed, can I switch from macro to the principal view and select an object with the selection tool ? It would really help me out if it worked.
Thanks in advance,
Gweltaz
  • Hello,
    there is a worked-out sample doing what you look for here: https://www.klayout.de/useful_scripts.html#calc_area.lym
    Thanks for your help.
    Regardless, can you explain why I would have the problem I show ? I fear I have difficulties understanding the functioning of the class system...
    Gweltaz
  • You're calling the methods on the classes, but they are methods you need to call on objects.
    So instead of
    ... = RBA::LayoutView::object_selection
    you probably want to say
    # gets the current LayoutView **object**
    layout_view = RBA::LayoutView::current
    ... = layout_view.object_selection
    Classes and Objects are basic concepts in object oriented programming.
  • I finally understood it just yesterday while coding for another macro!
    It makes perfect sense, now that I know !
    Thanks a lot!
