I built pythod wheel from git source (0.28) using Microsoft VS 2017 (and a few tools installed at MSYS2). But "python setup.py build" would not generate wheel file. So I built it by the following commands.
set PATH=c:\msys64\usr\bin;%PATH%
set "PATH=c:\Program Files\cmake\bin;%PATH%"
set "PATH=c:\strawberry\perl\bin;%PATH%"
set "PATH=C:\Users\ywko\AppData\Local\bin\NASM;%PATH%"
set "PATH=C:\Users\ywko\AppData\Local\Programs\Python\Python310\;%PATH%"
set "PATH=C:\Users\ywko\AppData\Local\Programs\Python\Python310\Scripts\;%PATH%"
set KLAYOUT_BITS=C:\klayout_bits4msvc2017-master\buildtemp\msvc2017\x64
python -m build
This generated a wheel and I can install it with pip command. But, "import klayout.db" results in "ImportError: DLL load failed while importing dbcore". After comparing it against PyPi version, I found binaries (such as libcurl.dll) from klayout_bits folders are missing. So, I copied those binaries to klayout installation folder. And it works well now.
Since this is the first time for me to build a wheel from source, maybe I did something wrong. What did I miss?
For building the wheel, you usually simply have to use
But you will find wheels for Windows in the artefact section of the Azure CI pipeline for example here : https://dev.azure.com/klayout/klayout/_build/results?buildId=1451&view=artifacts&pathAsName=false&type=publishedArtifacts
Since I wanted to build python module with DXF reader plugin sources modified to suppress warning messages, I couldn't use existing distributions. Thanks to your suggested link, after checking Azure pipeline logs, I found how to fix built wheel. Now, I can fix wheel using fix_wheel.sh found under ci-scripts folder. Thanks a lot.
And I found help message in fix_wheel.sh is a little misleading.
could be improved like this
Maybe you do not need to build yourself ... I have merged this patch two days ago: https://github.com/KLayout/klayout/issues/1138
So there is a way to suppress DXF (or in general) reader warnings now (0.28).
Good to know the added feature.
But, wheels for Windows at Azure still do not seem to include the feature. A wheel built from git source downloaded today works as expected (warn_level = 0 suppresses all warning messages). Happy.
Hi Matthias, I wanted to ask about suppressing warnings in the python terminal output. I wrote a data collection python script that iterates through a list of separate .oas files and parses their data.
Even with starting off my main method with:
" import klayout.db as kl
options = kl.LoadLayoutOptions()
options.warn_level = 0 "
I am getting "Warning: Type 0 or 1 point list with odd number of points is illegal (position=27938, cell=#0)" repeated over and over again each time I call layout.read() on my next file. Is there any way to suppress this output?
Should I open a new thread on the forum for this? Thanks
Yes, new thread please. This is entirely unrelated.
But I'd take the warning serious. Maybe you can share a sample file that produces the warning, and I can help debugging. With sane OASIS files, no warnings should be seen.
And maybe you can share the call to "layout.read()". I assume you're not passing the options object to the call. Otherwise the warnings should go away. But again, consider fixing your OASIS file. It is damaged.
"And maybe you can share the call to "layout.read()". I assume you're not passing the options object to the call. Otherwise the warnings should go away. But again, consider fixing your OASIS file. It is damaged."
This was it -- thank you so much! I forgot to pass the options as an argument in the layout.read call. I will also look into what might be wrong with our OAS files.
Best Regards,
SWendell
