Okay, the application should not crash ... but you're passing an invalid layer id to get_info.
get_info takes a layer ID which you get when you know the GDS layer number/datatype. A layer ID is an internal layer index and typically is a low number. You can obtain it when you create or request a layer from a GDS layer/datatype number:
ly = ...
layer_id = ly.layer(10, 0) # for GDS layer 10, datatype 0
info = ly.get_info(layer_id) # should give you back layer 10/datatype 0
get_infotakes a layer ID which you get when you know the GDS layer number/datatype. A layer ID is an internal layer index and typically is a low number. You can obtain it when you create or request a layer from a GDS layer/datatype number:Matthias
Hi @Matthias
Yes, it is an invalid layer id.
Thank you,
dai
