Klayout get crash when run get_info
Hi @Matthias ,
I run two commands below and get app crash .
ly = RBA::CellView::active.layout
ly.get_info(1000000001)
Please find attached gds also.
Thank you,
dai
  • Okay, the application should not crash ... but you're passing an invalid layer id to get_info.
    get_info takes a layer ID which you get when you know the GDS layer number/datatype. A layer ID is an internal layer index and typically is a low number. You can obtain it when you create or request a layer from a GDS layer/datatype number:
    ly = ...
    layer_id = ly.layer(10, 0)   # for GDS layer 10, datatype 0
    info = ly.get_info(layer_id)     # should give you back layer 10/datatype 0
  • Hi @Matthias
    Yes, it is an invalid layer id.
    Thank you,
    dai
