Convert txt file to gds file
edited May 2023 in Python scripting
Dear Sir,
I want to convert txt file to gds file and the "gds2_multi_xy_records" must be true when do export setting.
("Multi-XY record mode for boundaries (enable infinitely large polygons/paths at the cost of compatibility)")
Could you help to provide relative demo python code for this options if possible?
B/Rs
Chen Zhou
  • edited May 2023
    Thanks for Matthias's help.
    1) It can work by "--multi-xy-records" option in strm2gds command
    2) The options can be obtained by "strm2gds --help-all >xxx" in windows, the help can be redirecting to a file
  • Thanks for sharing this insight with the others! :)
