DISABLE "SAVE" and SAVE AS" on unix
edited January 2018 in General
Hello to all,
I need your help to understand if it's possible and How disabled "save" and "save as" button on graphics interface on unix
Let me know how can proceed
Best regards
Luciano
  • edited November -1
    Ciao Luciano:
    Can you clarify your question? Do you *want* the buttons disabled, or for some reason they are disabled and you don't want them disabled?
    Best regards, Erwin
    Ciao,
    Ok, I want the buttons disabled
    Luciano
    Hi 71lucky,
    have a look at the thread
    https://www.klayout.de/forum/comments.php?DiscussionID=700
    klayout_vo_app.exe should do what you are looking for.
    regards
    Stefan
    thanks Stefan.
    On unix I used version 0.23.11 (the last one that I can use)
    How can I use the script
    menu = mw.menu
    menu.action("file_menu.save").visible = false
    menu.action("file_menu.save_all").visible = false
    menu.action("file_menu.save_as").visible = false
    menu.action("@hcp_context_menu.save_cell_as").visible = false
    on unix?
    Many thanks in advance
    Ciao
    Luciano
  • edited January 2018
    Hi all,
    yes, that's the way I'd do it too .. please note that skilled users could still do that in the macro IDE or potentially in other places. You'd not achieve total safety unless you disable these features too.
    Some features that can potentially used to save layout:
    • DRC
    • Shapes to markers (save marker DB)
    • The net tracer (export nets)
    If you include images:
    • Print
    • Save screenshot
    And I'd bet a criminal mind could come up with many more options :-)
    Clear Matthias, thannks
    But how can run the script on unix?
    Luciano
    I have copied the script in a file myscript.rbm and run it on this way
    klayout -r myscript.rbm
    but doesn't work
    Please, can You help me?
    Luciano
    Solved.
    I have created file as myscript.rb and run it on this way
    using this command "Save" and "Save As" are removed on menu "File"
    Thanks to all.
    Luciano
    Sorry to all, one more question.
    It's possible run the script automatically, inserting the name on klayoutrc file?
    Thanks for the help in advance
    Ciao
    Luciano
    Hi Luciano,
    you can turn the script into a "generic macro" (*.lym file) and put it into ".klayout/macros". Such scripts can be configured to auto-run on start.
    This file can be created using "Macros/Macro Development", "New Macro" ("+" button) and chose "Generic KLayout Macro" for the template. Rename the macro, paste your script text and in the macro properties (second tool button from the right above the macro text), enable "Run on startup".
    Hi Luciano,
    sorry, didn't read the KLayout forum during the last days.
    Another way to make the script autorun is to place it as *.rbm in the program folder to make it active for all users running klayout from that folder,
    or in your own KLayout folder, on Linux this should be ~/.klayout
    regards
    Stefan
    Hi Stefan,
    that's right, but *.rbm is deprecated in favour of the autorun .lym version. The effect is the same, but there are more options with .lym (for example, you can use Python).
  • I'm tryng to use the same file on version 0.29.0 but I received this error message.
    How can solve it??
  • Are you maybe trying to run KLayout in batch mode?
    "MainWindow" will not have an instance in that case. Hence RBA::Application::instance.main_window returns nil. In normal GUI mode, this should return the main window object.
  • Running this command line
  • I don't know what "myscript.rb" is in your case, but this works for me:
    myscript.rb:
    menu = mw.menu
    Run KLayout with:
    klayout -rm myscript.rb
    ("klayout -r myscript.rb" does not start KLayout, but exits after the script is executed).
