Rulers/Measure have stopped working...
I have no idea 'why' my rulers and measure have stopped working... Several other people in my group have noticed the same thing. Any ideas on how to fix?
Any and all help will be greatly appreciated!!
I searched for an answer to this before posting, but it doesn't look as if this is a wide-spread issue. I couldn't find any posts about this.
  • Hi,
    I guess that is related to a broken configuration. Could you try removing or renaming ~/.klayout/klayoutrc (Linux) or %HOME%\KLayout\klayoutrc (Windows)? This should make KLayout start with a clean configuration.
    In case you have configured KLayout to use a different file (through option -c or the KLAYOUT_HOME) environment variable), check this place.
  • Hi, Matthias,
    Thanks for the rapid response!
    I tried removing the %HOME%\KLayout\klayoutrc file and restarting KLayout - without success. The program started with a "clean" configuration, but I still could not measure or place a ruler.
    I have also uninstalled KLayout 0.25.7 and installed older versions (computer reboots in between) to try to get it working again - without success. One of the people in my group was using rulers one day and the next day it would not work. No change to the program at all. Very odd. I have no idea what to do now.
    Ideas?
    Kevin
  • Hi Kevin,
    Maybe there is a macro installed which somehow prevents using rulers.
    Macros are kept inside %HOME%\KLayout too in the macros, ruby etc folders. So you could rename the entire "KLayout" folder to something else. Then KLayout should start with a clean config and no macros.
  • I am having exactly the same issue just now. Installing the latest KLayout version did not work either. Any suggestion?
    Thank you!
  • I still have working rulers on Windows (0.26 DVB) and Ubuntu (0.25.8 )
    Might be that some software (dependency) got updated, and broke it at your site(s)?
  • Hi, my ruler has stopped working as well suddenly. So has my friend's ruler. Is there any software update/compatibility issue ? How can we tro
  • How can we troubleshoot this ?
  • I have not observed missing rulers and I there are many W10 and Linux installations I am watching ... on Mac there was (once) an issue with high-res displays which caused a similar problem. But this should be fixed.
    On W10 high-resolution display are becoming popular too. But I have access to at least two laptops with high-res display and none of them is showing this problem. If you're on W10, you can try tweaking the compatibility modes and check whether the problem disappears.
