Hi All,
I only know how to use GUI to run DRC, then save as the DRC report.
May I know how to use script to run DRC in terminal? for example, use for loop to check DRC for 10 GDS files and save the separate reports.
Then when finish, I can check one by one?
Another question is how to use script to check DRC for different CELL in one GDS, for example, one GDS contains 5 CELLs and I want to check them separately, and generate different report?
Thanks.
Shawn
Hi Shawn,
the way I do it is to use KLayout in batch mode and configure DRC with variables taken from the command line.
For example, in your DRC deck (e.g. "run.drc") you specify a source and report this way:
Then you run KLayout with this deck in batch mode and pass "input" and "output" by defining script variables:
If you want to pick a specific cell from the input layout, you can use one more variable - i.e. "cellname":
This looks like it should be paragraph 1, chapter 1 of the Klayout DRC Developer's Cookbook.
If we had one.
Hi @Matthias ,
Thank you very much!
One more question.
In the GUI, I can use
to get GDS file name without path, and the cell name in the GDS.
When I
source($input)
How can I get the GDS file name without path, and the cell name in the GDS?
Shawn
Hi Shawn
For the file without path use the Ruby toolbox:
For the cell name use
Hi @Matthias ,
Shawn
Sorry , more question for this topic.
As normally , we have many DRC command , such 1.lydrc / 2.lydrc
Can we call another DRC command in DRC ?
such as picture shown...
well, that's actually harder than it looks. There is a forum entry where I explain the topic: https://www.klayout.de/forum/discussion/comment/6738#Comment_6738
The problem is basically that DRC is based on Ruby which (like Python) is a modern language. It incorporates concepts such as AST compilation and compile unit-local namespaces. Although this is nice and good it makes partitioning of big serial chunks of code difficult.
In 0.27 I am proposing a pre-processor extension which adds a special feature to DRC scripts. This feature allows including other files through a simple pseudo-comment like this:
This will however only work for scripts executed within KLayout and debugging will be tedious outside KLayout because external debuggers will only see the expanded file.
firstly , I want to try to paste my code in the below , and change the format as a code ,
hope it is workable to let you see what my code...
second, as the attached file , I want to include (or "call" ) my DRC file .
that file was named "DRC_width_loop.lydrc"
but , I get a message as picture and didn't know what the issue happen
Could you please help ?
please let me explain more detail for the request...
this is our DRC command file for 1 of part.(the DRC named "psv1.lydrc)
and I also shown "PKG-8.lydrc " which is the DRC command we have to "call " or "include"
Cause we have to run "PGK-8.lydrc" in first ,to output layer 1000/1.... then go to check other rule in the first DRC command .(psv1.lydrc)
we also need to call (include) other DRC command , that is why I asking for the function.
and as the picture below , I got some error message , please help it...
Thanks very much~
this is what the DRC command in PKG-8.lydrc
@jiunnweiyeh
"lydrc", "lym" ... are XML formats which KLayout understands but not Ruby or Python. KLayout will use the XML attributes to store meta information such as where and how to show the script in the menu.
In order to "load" a file, it needs to be in plain text (.drc).
And please remove the "# %include ..." comment - it will confuse KLayout in the next release.
Hi Matthias
Got it , it is work , Thanks very much for your help.
one more question , if the text file location at network , such as below.
\obu3pie-nas01\OBU3PIE_Presonal_Databackup\Mask\sample
how to make file.join to link it?
include_file = File.join(File.dirname(__FILE__), "PKG-8.lydrc")
@jiunnweiyeh
I usually don't see issues with "File.join" or "File.dirname" with proper paths, even on Windows network drives. The network path should be a valid UNC path however which is starting with a double backslash, like
\\nas\Personal\...
.Matthias
Hi @Matthias ,
May I know is it possible that we run drc check in windows system batch mode?
currently in Windows CMD, I can use following command to run
C:\Users\user1\Downloads>C:\Klayout\klayout-0.26.9-win64\klayout_app.exe -r C:\Users\user1\KLayout\drc\DRC.lydrc test.gds
The KLayout GUI will start and check the GDS.
However if I add -b option, it will not run. is it possible we add -b option to make it run at background?
@TryAndTry In batch mode you cannot give a file as an argument because there is no GUI to load it into.
You also need to specify where to write the report or output layout to.
You can pass this information from the command line using variables. This is how I do it:
In the DRC:
This is how you call this script in batch mode:
