XOR on an area
edited February 2012 in General
How to make a XOR between 2 GDS layout, but only on a defined area, not on the whole chip ?
OkGuy
  • edited 3:58PM
    Hi OkGuy,
    that's actually a nice suggestion for a new feature :-)
    right now it's possible to run an XOR on a subregion by creating clips and running the XOR on those clips.
    This is fairly convenient by following this recipe:
    • Start KLayout in editor mode
    • Load both layouts into the same view
    • Draw a ruler from one corner to the opposite corner of the rectangle you want to run the XOR on
    • Use Edit->Utilities->Clip and select "From ruler start to end points" to make the clip. A new cell "CLIP" will be created containing only the region of the clip.
    • Switch to the other layout (drop down box above the cell list)
    • Repeat the clip step for this layout
    • Run the XOR, now on the clip cells
    Maybe that is helpful.
