that's actually a nice suggestion for a new feature :-)
right now it's possible to run an XOR on a subregion by creating clips and running the XOR on those clips.
This is fairly convenient by following this recipe:
Start KLayout in editor mode
Load both layouts into the same view
Draw a ruler from one corner to the opposite corner of the rectangle you want to run the XOR on
Use Edit->Utilities->Clip and select "From ruler start to end points" to make the clip. A new cell "CLIP" will be created containing only the region of the clip.
Switch to the other layout (drop down box above the cell list)
Hi OkGuy,
Maybe that is helpful.
