Hi all, I am a postgraduate student, I am trying to write some rules, and I have some questions.
First, I wanna check the width, but I also wanna ensure the width is not affected by some polygons with the wrong angle, What should I do?
This is what I done , What should I add to achieve a more complete width check?
min_aa_w = 500.nm
r_aa_w = aa.width(min_aa_w )
r_aa_w.output("AA_W: AAwidth < 0.5 µm")
I used calibre for DRC inspection before. I also want to know what is the biggest difference between Klayout and Calibre for DRC?
Second,How to write a DRC script when checking the distance between different nets?
The specific requirement is Space between DNW and NW at different nets
I just write like this, but I do not know how to write "different net"
min_DNW__NW_s = 300.nm
r__DNW__NW_s = dnw.separation(nw, min_DNW__NW_s )
r__DNW__NW_s.output("DNW__NW_s: space to nw distance < #{'%.12g' % min_DNW__NW_s } µm")
Thanks in advance!
Best wishes!
Shida
Ok , i know how to write the rules to check the angle now, but I still confused on different nets problem..
@Shida I'm sorry, but KLayout currently can't check distances between different nets. Thats a development branch which is not yet addressed.
Please don't expect you can easily substitute Calibre by KLayout. Mentor doesn't take the money for no reason.
@Matthias
Thank for you reply!
Ok, That makes sense..
Where can I know the difference between Klayout and Calibre? I am very curious.
Maybe the GDS design I made is not so complicated. I compared the two software myself, and I began to think that there was no difference between Klayout and Calibre.
I really respect you very much. I think klayout really helps a lot of people who can't afford calibre to learn!
Best wishes!
Shida
By the way,
I am trying to check some polygons with 45-degree edge.
min_edge_aa_fourfive = 0.45um
edge_aa_fourfive = aa.with_angle(45.degree)
r_aa_width_fourfive = edge_aa_fourfive.width(min_edge_aa_fourfive )
r_aa_width_fourfive .output("AA_W with 45 degree : AAwidth 45 degree < 0.45 µm")
But it does not work
Thanks in advance!
You can find many DRC examples here :
https://github.com/laurentc2/SKY130_for_KLayout/blob/main/drc/drc_sky130.lydrc
https://github.com/laurentc2/FreePDK45_for_KLayout/blob/master/drc/drc_freepdk45.lydrc
For your 45 degree DRC :
or more simple :
Laurent
Thanks @laurent_c
Thanks, @laurent_c , I still confused...
In your code, it selects the 45 degrees, but what I wanna do is to check the width of 45 degrees of aa
how can I do that?
Sorry, here is the way to check it :
Laurent
Thanks! @laurent_c
You are so nice! It helps me a lot.
I have already read all the code you upload in github, it is very Conciseness but useful, and I learn a lot!
Wish you have a good day.
BEST WISHES
Shida
