Combine RBA::InputDialog.get_string and RBA::InputDialog::ask_item
edited January 14 in Ruby Scripting
Is there a way too combine RBA::InputDialog.get_string and RBA::InputDialog::ask_item
into one dialog window
  • @tagger5896 The only way is to create a custom dialog.
    You'll need some Qt knowledge for this purpose. A good starting point is the "Qt dialog sample" you can select when you create a new macro in the IDE.
  • Matthias,
    Thanks figured out
     dialog = QDialog.new(Application.instance.main_window);
     dialog.resize(400,200)
     dialog.windowTitle = "Test Box";
     qt_layout = QVBoxLayout::new(dialog);
     dialog.setLayout(qt_layout)
     # Define the Net combo box
     combo_net = QComboBox.new(dialog)
     unique_nets.each { |p|
           combo_net.addItem(p) #nets[0] will be selected initially
    # Define the Layers combo box
     combo_layers = QComboBox.new(dialog)
          in_lyp.each { |p|
          combo_layers.addItem(p) # layers[0] will be selected initially
     # Add the combo box to choose net
     qt_layout.addWidget(combo_net)
     # Add the combo box to choose layers
     qt_layout.addWidget(combo_layers)
      # OK button
      buttonOK = QPushButton.new(dialog)
      qt_layout.addWidget(buttonOK)
      buttonOK.text = " OK "
      buttonOK.clicked do
           dialog.accept()
     #Get Result of Combo box
      result = dialog.exec
      result == 1 ? accepted = true : accepted = false
      input = combo_net.currentText + "." + combo_layers.currentText
      puts input
  • Very good! That's example what I meant.
    Thanks for sharing the code! :)
    Warm regards,
  • Matthias
    TYVM slowing wrapping my head around Ruby and python
