Is there a way too combine RBA::InputDialog.get_string and RBA::InputDialog::ask_item into one dialog window
@tagger5896 The only way is to create a custom dialog.
You'll need some Qt knowledge for this purpose. A good starting point is the "Qt dialog sample" you can select when you create a new macro in the IDE.
Matthias,
Thanks figured out
dialog = QDialog.new(Application.instance.main_window); dialog.resize(400,200) dialog.windowTitle = "Test Box"; qt_layout = QVBoxLayout::new(dialog); dialog.setLayout(qt_layout) # Define the Net combo box combo_net = QComboBox.new(dialog) unique_nets.each { |p| combo_net.addItem(p) #nets[0] will be selected initially } # Define the Layers combo box combo_layers = QComboBox.new(dialog) in_lyp.each { |p| combo_layers.addItem(p) # layers[0] will be selected initially } # Add the combo box to choose net qt_layout.addWidget(combo_net) # Add the combo box to choose layers qt_layout.addWidget(combo_layers) # OK button buttonOK = QPushButton.new(dialog) qt_layout.addWidget(buttonOK) buttonOK.text = " OK " buttonOK.clicked do dialog.accept() end #Get Result of Combo box result = dialog.exec result == 1 ? accepted = true : accepted = false input = combo_net.currentText + "." + combo_layers.currentText puts input
Very good! That's example what I meant.
Thanks for sharing the code!
Warm regards,
TYVM slowing wrapping my head around Ruby and python
Matthias,
Thanks figured out
Warm regards,
