import math
This Code implements a Serpentine PCell
It will generate a path starting from 0,0 and produce a serpentine this
way:
| | | | s
| V | |
+->+ +->+ V
<-> u
The parameters are:
- l: the layer to use
- w: the width of the path
- n: the number of vertical paths
- u: see drawing above
- s: see drawing above
NOTE: using negative angles makes the Serpentine turn the other way
class Serpentine(pya.PCellDeclarationHelper):
The PCell declaration for the Serpentine
def __init__(self):
super(Serpentine, self).__init__()
# declare the parameters
self.param("l", self.TypeLayer, "Layer", default = pya.LayerInfo(1, 0))
self.param("n", self.TypeInt, "Number of points per full turn", default = 5)
self.param("w", self.TypeDouble, "The width", default = 1.0)
self.param("u", self.TypeDouble, "One turn's pitch", default = 2.0)
self.param("s", self.TypeDouble, "The turn's length", default = 20.0)
def display_text_impl(self):
# Provide a descriptive text for the cell
return "Serpentine(L=%s,S=%.12g,U=%.12g" % (str(self.l), self.s, self.u)
def produce_impl(self):
# compute the Serpentine: generate a list of spine points for the path and then
# create the path
pts = []
x = 0.0
y = 0.0
for i in range(0, self.n):
pts.append(pya.DPoint(x, y))
x += self.u
if (i % 2) == 0:
y += self.s
else:
y -= self.s
# One last point to move to the end location
x += self.u
# create the shape
self.cell.shapes(self.l_layer).insert(pya.DPath(pts, self.w))
class SerpentineLib(pya.Library):
The library where we will put the PCell into
def __init__(self):
# Set the description
self.description = "Serpentine PCell Library"
# Create the PCell declarations
self.layout().register_pcell("Serpentine", Serpentine())
# Register us with the name "SerpentineLib".
self.register("SerpentineLib")
# Instantiate and register the library
SerpentineLib()
Thank you very much, Matthias. It's really helpful. Btw, I'm a beginner with Klayout script. Do you know where can I find the documents about classes in "pya" package. e.g. I want to know all the parameters and methods in pya.PCellDeclarationHelper. Where can I find that?
I had once created a PCell with such a code.
I'll share it here:
This is a sample image:
thank you very much,
Zuyuan
@ZuyuanTian I can offer the documentation which is online:
Basics: https://www.klayout.de/doc-qt5/programming/index.html
PCellDeclarationHelper: https://www.klayout.de/doc-qt5/code/class_PCellDeclarationHelper.html
