How to do Object to Polygon, Stretch by x or y, Split object?
edited July 2012 in General
I'm a new user of this tool. Thank you for the great piece of software. On top of being free and offering some very unique features, I also find it quite stable and intuitive to use.
There are a few things that I don't know how to accomplish easily in the current software. I was wondering if you could comment on the solutions for:
a) Box or Path to Polygon transformation.
b) Stretch edge(s) by x or y.
c) Split an object into 2 by drawing a cut line.
Thanks for your support.
-Ken
  • edited July 2012
    Hi Ken,
    thank you for your encouraging feedback :-)
    Regarding your questions:
    • you can convert paths or boxes to polygons with the "merge" operation. Select the path or box and choose "Edit/Selection/Merge Shapes". The result will be a polygon.
    • What do you mean by "stretch"? There is a "size" operation (in "Edit/Selection/Size Shapes") which will enlarge a shape by a given dimension. It can also apply a different enlargement in x and y direction.
    • Cutting is not supported directly yet, but you can subtract something from another object. This can be used to separate a shape into two parts: draw a thin path along the line you want to cut the shape, select the original shape and then select the path in addition by using "Shift" and a left mouse button click. Then choose "Edit/Selection/Subtraction" and the path will be subtracted from the original shape. If the path was cutting through the shape you will get two pieces which are separated.
    Hope that helps.
  • edited 12:47AM
    Thanks for the tip on "merge" operation to change path or box to polygon. It works great!.
    On the "stretch" item, I was looking a feature to do a "partial" by specifying an x or y displacement (in a dialog box) as opposing to using the cursor to drag the edge(s).
    Thanks for your help.
    -ken
  • edited 12:47AM
    Hi Ken,
    right now there is no "dialog box" stretch feature, although that is a nice suggestion.
    But you could set a coarse grid which allows to drag a distance more precisely because dragging will be confined to distances which are a multiple of the grid.
  • edited 12:47AM
    On the same topic, I am using the latest version of KLayout, on MAC OS 10.7.
    When I use "size shape" command on a box, its size changes randomly. The result is not even close to what I requested. Is it a bug ? How should I proceed ?
  • edited 12:47AM
    Hi Jean,
    Please see my notes on the other entry of yours.
  • edited 12:47AM
    I have seen it and it was most helpful. Thank you.
