I'm a new user of this tool. Thank you for the great piece of software. On top of being free and offering some very unique features, I also find it quite stable and intuitive to use.
There are a few things that I don't know how to accomplish easily in the current software. I was wondering if you could comment on the solutions for:
a) Box or Path to Polygon transformation.
b) Stretch edge(s) by x or y.
c) Split an object into 2 by drawing a cut line.
Thanks for your support.
-Ken
Hi Ken,
thank you for your encouraging feedback :-)
Regarding your questions:
Hope that helps.
Thanks for the tip on "merge" operation to change path or box to polygon. It works great!.
On the "stretch" item, I was looking a feature to do a "partial" by specifying an x or y displacement (in a dialog box) as opposing to using the cursor to drag the edge(s).
Thanks for your help.
-ken
Hi Ken,
right now there is no "dialog box" stretch feature, although that is a nice suggestion.
But you could set a coarse grid which allows to drag a distance more precisely because dragging will be confined to distances which are a multiple of the grid.
When I use "size shape" command on a box, its size changes randomly. The result is not even close to what I requested. Is it a bug ? How should I proceed ?
Hi Jean,
Please see my notes on the other entry of yours.
