Output within a DRC engine instance fail to generate report database
This code works.
source("test1.gds")
report("Firt sample database", "out.lyrdb")
input(1, 0).sized(200.nm).output("sized","error")
But, this code would not produce out.lyrdb file. What am I missing?
eng = DRC::DRCEngine::new
eng.instance_eval do
    source("test1.gds")
  • edited June 21
    @yangwoo You need to call "eng._finish" finally to flush the report to a file.
    But you're playing with internals here. You should be able to read the original code when you plan to do so.
  • @Matthias Thanks for comments. Borrowed two lines of codes from eng._flush and now it works.
