[Bug] Resizing box to 20 x 3000 micrometers
edited September 2012 in General
I tried to draw the simple pattern described in the attached pdf file (see link below) using KLayout editor for MAC OS X.
However, I can't manage to resize a simple box. I would like to :
- Set the size of the rectangle (for instance 20 microns x 3000 microns).
- Set its position on the layout (coordinates).
but KLayout is not letting me do that. The "size shape" command has little or no effect. I suspect a bug, but I am unsure.
Jean
The project :
https://depot.u-bourgogne.fr/?dlid=151f16f2061e97e9419925a4d0825d5a
  • edited September 2012
    To give some additional details, when I do Edit->Selection->SizeShapes and set a value (for instance: "20, 3000"), the shape slightly changes size, but looks really more like a big square, than like the thin rectangle it should be… I must be missing something...
  • edited 12:55AM
    Hi Jean,
    To move a shape that you have already drawn, use the "move" mode. Select this mode, pick the shape you want to move and drop it at the desired location.
    To resize a box, use the "Partial mode". This lets you select a corner or edge of the box and move it.
    To resize a box numerically, double-click the box and change the values in the properties dialog.
    The "size" function enlarges a polygon by shifting the edges outward by the given distance or inward for a negative distance. "Sizing" is a term frequently used to describe this operation. Another term often used in that context is "bias".
    You'll find that information and some more in the manual section of this site.
  • edited 12:55AM
    Thank you very much for your reply.
    I used your technique (double-click the box and change the values in the properties dialog) and, indeed, it works.
    However, I can't resize the box using width/length. I must enter the coordinates. It is an inconvenient, but I can do with it.
    Do you know why Edit->Selection->SizeShapes isn't working ?
    Jean
  • edited 12:55AM
    Hi Jean,
    the current version 0.22 allows to edit the boxes width/height.
    The size function should work - I use it frequently myself. Maybe you can be more specific, i.e. give a precise recipe how to reproduce that problem. I may have a chance to take a look at it then.
