Return of DRC is not edge pair
Hi all,
I have some DRC following:
input1.drc(enclosed(input2,projection) == 2.nm) # return edges
input1.drc(enclosed(input2,projection) <= 2.nm) # return edges
input1.drc(enclosed(input2,projection) < 2.nm) # return edge pairs
I expect the result of three cases above is edge pair only. Do you know why?.
Thank you.
dai
  • @dai This is documented here: https://www.klayout.de/doc-qt5/about/drc_ref_global.html#width
    The definition of the "==" operation is not trivial and eventually it is implemented as "<" check which strikes out the "closer" parts and a ">" check which strikes out the "further" parts. These are boolean edge operations on the original edge which renders edges only.
    "<=" is implemented as "not >" which is also a boolean operation and leaves edges for the same reason.
    I may change this in the future, but as of know that is how it is implemented.
  • Thank you, @Matthias
    dai
