Hi!
I'm trying to add some simple python modules such as draw circles and align cells. Also, I have written some scripts to generate a bunch of cells and shapes.
Is there a way to achieve undo without writing the entire layout file and then reads? I went through a bunch of documents, and I was not able to find them.
Thank you very much!
So you use
pya.Layoutobjects and we're not talking about UI, right?I assume you do something like:
The correct way of taking a snapshot without read/write is to use
dup:Does that answer your question?
Thank you very much for your answer!
I am sort of talking about UI, I tried your method, but it won't update the layout in the window view.
I wonder is there a simpler way of doing that?
I have not noticed (in GUI use) any significant wall time
for saving entire layout. Maybe two seconds to load and
paint at 4K, a full wafer layout from disc (4", 4um feature
size, but still - these are fully functioning IC process and
circuit coupons). Are you overthinking this, particularly the
weight given to the anticipated penalty? For fiddling with
circles, I don't think you'll see it.
Hi there!
It's not just circles, as I am trying to add a few other implementations, and I find both loading and this new way would not be ideal since they both overwrite the original undo stack.
But here is the way that I discover to load the snapshot, you can go use
view.show_layout(layout, False)but I do wonder if there is a way you can also keep the undo stack.view as the
layoutviewclassI wonder, is there a way I can add something directly into the undo stack of Klayout itself? or something that won't overwrite the previous undo stack.
Thank you!
The formal way of adding undo to any script of yours is the following:
"transaction" will start a block of recorded operations. "commit" will close it. After commit, a new Undo item will be on the Undo stack which undos/redos the operations within "your code".
Is that what you are looking for?
omg this is amazing! Thank u!
Looks like I hit the nail on the head!
