I think I found and fixed the problem. Basically, the options are there, but only visible when you use some of the drawing modes.
I want to release this fix with 0.28.4, but you can test upfront using the master builds from here: https://www.klayout.org/downloads/master/ (disclaimer: binaries not signed, no MacOS).
Forget 0.28.1. Does this problem still exist on 0.28.3?
Yes. At least in the no-installer version. I will check the exe installer.
I have the same problem with v0.28.3 also
I don't have Windows 11 myself yet.
But you did not select a tool. There are not options on the select tool, the editor options are empty.
When you select a tool - e.g. "move" or "box" - will "F3" work then?
Kazzz-S
@sekigawa Thanks for these screenshots! I see that is somewhat inconsistent. I'll try to fix that.
I also observe the same A), B ), C) behaviour as detailed above.
@Matthias Thank you for the quick fix
It's OK on MacOS, too.
Kazzz-S
I have just checked the new build 0.28.4 and now all seems to be working as expected.
Thanks you very much for your quick fix!
Very good. Thanks for this feedback!
Removed. Wrong topic post
Oops, posted in the wrong topic
