Counting number of cell instantiations using "begin_instances_rec"
Hello Matthias and all,
I'm trying to make a script to count the number of instantiations of each sub cell inside the currently viewed cell using the method "begin_instances_rec". I get some weird results and I can't figure out what's going wrong. I'm (still) using version 0.27.13.
module MyMacro
  include RBA
  layout_view = Application.instance.main_window.current_view
  cell_view = layout_view.active_cellview
  layout = cell_view.layout
  viewed_cell = cell_view.cell
  sub_cell_names = []
  counter = 0
  viewed_cell.called_cells.each do |cell_index|
      sub_cell_names << layout.cell(cell_index).name
      counter += 1
  end # each
  sub_cell_names.sort!
  line_length = sub_cell_names.map{|string| string.size}.max + 10
  puts "Number of cell instantiations in viewed cell \"#{viewed_cell.name}\" (#{counter} different sub cells detected):\n\n\n"
  iterator1 = viewed_cell.begin_instances_rec
  sub_cell_names.each do |sub_cell_name|
      counter = 0
      iterator1.targets = sub_cell_name
      while !iterator1.at_end?
        counter += 1
        iterator1.next
      end # while
      number_of_spaces = line_length - sub_cell_name.size - counter.to_s.size
      puts sub_cell_name + " " * number_of_spaces + counter.to_s
  end # each
end # MyMacro
Attached a gds test file with 4 top cells:
1) Number Of Cell Instantiations In viewed cell "TOP_CELL_1" (1 different sub cells detected):
CHILD_CELL_1 12
ok
2) Number Of Cell Instantiations In viewed cell "TOP_CELL_2" (2 different sub cells detected):
CHILD_CELL_2 12
CHILD_CELL_2_1 12
ok
3) Number Of Cell Instantiations In viewed cell "TOP_CELL_3" (3 different sub cells detected):
CHILD_CELL_3 12
CHILD_CELL_3_1 12
CHILD_CELL_3_1_1 0
ko ---> 0 should be 12???
4) Number Of Cell Instantiations In viewed cell "TOP_CELL_3_B" (4 different sub cells detected):
CHILD_CELL_3 12
CHILD_CELL_3_1 15
CHILD_CELL_3_1_1 2
CHILD_CELL_3_B 1
ko --> 2 should be 15???
  • edited April 27
    maybe a 'iterator1.reset' is missing before 'iterator1.targets = sub_cell_name'
    but I have not tested.
    Frank
  • Hi Frank,
    Thanks for the reply. I added the reset but it doesn't change a thing.
    I also ran the sample code listed in the documentation (https://www.klayout.de/doc-qt5/code/class_RecursiveInstanceIterator.html) on the attached gds file with top cell "TOP_CELL_3_B" selected and it gives only 2 references as well, instead of 15:
    Instance of CHILD_CELL_3_1_1 in TOP_CELL_3_B: r0 *1 120,40
    Instance of CHILD_CELL_3_1_1 in TOP_CELL_3_B: r0 *1 120,0
    The code is:
    module MyMacro
      include RBA
    #--------------------Input-------------------------
    instance_cell_name = "CHILD_CELL_3_1_1"
          iterator = viewed_cell.begin_instances_rec
          iterator.targets = instance_cell_name
          while !iterator.at_end?
            puts "Instance of #{iterator.inst_cell.name} in #{viewed_cell.name}: " + (iterator.dtrans * iterator.inst_dtrans).to_s
            iterator.next
          end # while
    end # MyMacro
  • @tomas2004 That looks like a bug, probably the arrays are not traversed properly in the recursion. I'll open a ticket. Thanks for reporting that and the testcase.
    Regarding your problem: the recursive instance iterator is not the right approach as it will traverse the hierarchy far too often in the general case. You only need to sum up weighted counts, like here:
    def collect_counts(cell, weight, counts)
      counts[cell.name] ||= 0
      counts[cell.name] += weight
      cell.each_inst do |inst|
        w = weight * inst.size
        cc = cell.layout.cell(inst.cell_index)
        collect_counts(cc, w, counts)
    layout_view = RBA::Application.instance.main_window.current_view
    counts = {}
    collect_counts(viewed_cell, 1, counts)
    counts.keys.sort.each do |cn|
      puts cn + ": " + counts[cn].to_s
    This gives for "TOP_CELL_3B":
    CHILD_CELL_3: 12
    CHILD_CELL_3_1: 15
    CHILD_CELL_3_1_1: 15
    CHILD_CELL_3_B: 1
    TOP_CELL_3_B: 1
  • Ticket is here in case someone is interested: https://github.com/KLayout/klayout/issues/1353
  • Hi Matthias,
    Thank you for the improved code. It's indeed very fast :-)
